B16a Turbo Setups
Old Jun 18, 2010 | 11:55 AM
  #901
slodel's Avatar
Default Re: B16a Turbo Setups
270whp today 9lbs boost on spring
stock b16
all new everything else
treadstone turbo kit
kteller 3 inch exhaust
hondata
precision 440s with clips
2.5map
pretty happy
already planning for next yr
Old Jun 18, 2010 | 06:59 PM
  #902
TspEk9's Avatar
Originally Posted by TspEk9
finally got it tuned saturday i made 316hp and 248tq @18psi
i was ok with the results, but with that amount of psi i would expect more, but
i had alot of restriction, im thinking maybe it could be the mini log manifold, the stock cams, the exhaust piping was 2.5.
bad news, drove it on sunday, and all of a sudden a big cloud of white smoke came out
when i down shifted to 3rd gear so i had to pull over. coolant was low, oil was very milky, im hoping i blew a headgasket, and not cracked a sleeve.
So today i got a chance work on my other b16a block, and i decided to take a pic of the sleeves.
this block was gonna break a sleeve no matter what, found cracks in # 4 also. A chunk of the sleeve is missing causing it to hit the piston. **** happens
Old Jun 19, 2010 | 01:53 AM
  #903
95DC2GS-R's Avatar
this is my track/occasional DD car, the whole idea was to built a car that made nasty power and could be taken any where and looked good. Right now it's on wastegate pressure (5psi) street tuned. the boost hasn't been yanked up yet because I need to change my fuel regulator and I have a leaky valve seal or two once that's fixed it's time to max out the 3bar map sensor
quick run down:
81mm Golden Eagle sleeved b16a
Eagle 1.8L stroker kit/Eagle rods/SRP slugs 11.3:1
B161 head PnP, 5 angle valve job, Titanium springs/retainers
Victor X intake manifold, Blox billet throttle body
Skunk 2 Pro 1's and BDL cam gears
Turbo Elements T4 divided housing topmount
Precision Billet 6765
Custom core intercooler
Tial 44wg and BOV
Custom 3" charge piping w/ Hargett race couplers
4" full downpipe and exhaust
Walbro 255 intank feeding a Bosch 044 into FIC 1100cc injectors on E85
forgetting a lot more, but that's a general run down.
here's the old setup, on 13lbs and was putting a lengths on 600RR's, with 290whp @10k rpm on pump gas, the new setup feels almost as quick on 5lbs with no timing and only spinning to about 9600rpm
I'll get a current pic tomorrow
Old Jun 19, 2010 | 03:29 AM
  #904
TspEk9's Avatar
quick run down:
Tial 44wg and BOV
very nice
Old Jun 24, 2010 | 09:49 AM
  #905
"NastIE Garage"'s Avatar
My friends Budget B16 we built
331/230 to the wheels on 11.5 pounds
B16 head
Blox valve train
GSR cams
BLOX intake manifold and ITR TB
550 RC injectors
GodSpeed Ram horn
GodSpeed 50 trim 82 A/R
Tial waste gate
Blitz BOV
3" down pipe and exhaust
81.5 B16 Block with golden Eagle Block gaurd
USDM Nippon GSR pistons
Stock rods shot peened
Micropolished crank
ACL race bearings
OEM honda head gasket
JDM GSR tranny with LSD
Tuned By David @ Import Auto Pros on Crome Pro
Old Jun 24, 2010 | 11:12 PM
  #906
95DC2GS-R's Avatar
Old Jun 25, 2010 | 07:33 AM
  #907
kte324's Avatar
84mm Laskey Built
s2 tuner 1, pro springs & retainers, ferrea valves, victor x, 70mm tb, 3" ic piping
nuekin top mount t3/44, s362, 4" dp
walbro intank, 044 inline, ID 1000s
stock ignition with msd coil (need to upgrade)
586whp @ 24psi on C16, 507whp @ 20psi on 93oct.
Old Jun 25, 2010 | 08:17 AM
  #908
95DC2GS-R's Avatar
Originally Posted by kte324
84mm Laskey Built
What's your compression if you don't mind me asking? I would love to go back to pump gas but mine is a 11.3:1 motor, it loves E85 and is making 300whp on 5lbs
Old Jun 27, 2010 | 06:24 PM
  #909
kte324's Avatar
9:1
Old Jun 27, 2010 | 06:32 PM
  #910
spoolin turbo s's Avatar
B16 head
Blox valve train
GSR cams
550 RC injectors
GodSpeed Ram horn
Tial waste gate
Blitz BOV
Micropolished crank
ACL race bearings
the 82 hotside is absolutely KILLING your powerband
Old Jul 1, 2010 | 06:18 AM
  #911
b16racereg6's Avatar
if any of you guys happend to have a stock b16 throttal body you want to sell please pm me thanks
Old Jul 1, 2010 | 08:57 AM
  #912
blaze the chemi's Avatar
Stay with E85 if you can. I'm sure you could go with 93oct, but you'd have to dial up that map much more conservatively. How is your motor 11.3:1? Did you mill the head and/or put higher CR pistons in?
Old Jul 1, 2010 | 09:41 AM
  #913
rs250nut's Avatar
84mm Laskey Built
Do you use this car on the street? if so what clutch are you using?
Old Jul 12, 2010 | 11:24 AM
  #914
Old Jul 13, 2010 | 08:58 AM
  #915
lst_hatch's Avatar
retuned friday. turned up the boost to 12psi made 320whp & 210tq! went to the track saturday best time was 12.07 @ 115mph
Old Jul 13, 2010 | 06:18 PM
  #916
sick man good times.... i am still working out bugs in my car and waiting on parts
Old Jul 13, 2010 | 07:12 PM
  #917
lst_hatch's Avatar
thanks my cars still full weight so time to put her on a diet and get into the 11's lol... gl with ur car!!jst dont give up on it!
Old Jul 14, 2010 | 05:43 AM
  #918
yeah i am not going to quit **** that came to far lol. yeah man put it on a dite get it into the 11's try and flim it too!!!!
Old Jul 14, 2010 | 09:11 AM
  #919
lst_hatch's Avatar
ya next time i go out ill have my girl recored some videos!
Old Jul 23, 2010 | 02:48 PM
  #920
Retuned my b16/Ls piston daily
Old Jul 23, 2010 | 06:21 PM
  #921
nels00n's Avatar
Originally Posted by 95dxsir2
how'd your run your dipstick w this turbo mani? i have the same mani lol
Old Jul 24, 2010 | 06:08 AM
  #922
good ****
Old Jul 25, 2010 | 08:46 PM
  #923
99V-unit's Avatar
here is my set up
81.5mm b16 stock crank
srp 8:3 pistons
crower rods
b16 automoatic cams (switched to gsr after dyno)
stock port head with bri9an crower valve train
turbo is garrett t3/60-1 .70 ar with .63 exhaust
3inch downpipe
1000cc rc injectors
aebs manifold
stock throtle body.
e85
car made 371whp at 13psi of boost.than my valve adjustment got loose
now i got gsr cams, victor x, 1200cc rc injectors self tuned. 23.5 degree timimg top end.
I gort a problem tho, its a daily driver and in socal 90 degree weather it gets very hot like 240temps driving on the freeway the other day not boosting. Its got 3core ebay radiator 12inch slim fan and fresh fluids. Also oil pressure starts going down after a while driving on the freeway any ideas?
Old Jul 31, 2010 | 02:33 AM
  #924
redskull1944's Avatar
bump for my JDM b16a I got for $150
Old Aug 4, 2010 | 12:29 AM
  #925
reborn101's Avatar
here's mine
stock b16a with complete ITR head
garrett gt35r
custom ramhorn mani
turbonetic wastegate
injector dynamic 900cc injectors
hondata s300
apexi avc-r boost controller
skunk2 intake mani
cometic headgasket
exedy heavy duty clutch
s80 gearbox
3 bar map sensor
walbro 255 fuel pump
its producing 220kw atw @ 10psi
the block is getting rebuild soon.
