B16a Turbo Setups
JDM B16A OBD1 SiRII - HMotorsOnline
Bone stock
ARP Headstuds
Competition Stage 4 clutch
T3/T04e 50 trim / .63 exhaust
SpoolinPerformance.com log manifold
SpoolinPerformance.com 3" downpipe with flex
SpoolinPerformance.com 1.5" open dumptube
Full 3" exhaust
Tial 38mm
450cc DSM injectors
Tuned by Mikey Meyagi
235whp @ 8200rpm @ 6.5psi
Bone stock
ARP Headstuds
Full 3" exhaust
Tial 38mm
450cc DSM injectors
Bone stock
ARP Headstuds
Full 3" exhaust
Tial 38mm
450cc DSM injectors
Bone stock
ARP Headstuds
Full 3" exhaust
Tial 38mm
450cc DSM injectors
i'm cheap so i bought myself a 34.3mm freeze plug from a local parts store and weld a -10AN barb fitting and am done. boosting for the last 1500+miles with zero oil leak.
PR3 head
Port and polished by NastIE Garage
3 angle valve job
Blox valve train
GSR Cams
AEBS Intake manifold
550 RC Injectors
Golden Eagle Head Studs
t3/t4 57 trim
Ram Horm
3" down pipe and piping
tial 34mm waste gate
81.5 B16 Block
Nippon LS PR4 Pistons
BDL Block gaurd
ELEVEN POUNDS 323 WHP 91 octane
3 angle valve job
Blox valve train
GSR Cams
550 RC Injectors
t3/t4 57 trim
Ram Horm
81.5 B16 Block
BDL Block gaurd
PR3 head
3 angle valve job
Blox valve train
GSR Cams
550 RC Injectors
t3/t4 57 trim
Ram Horm
81.5 B16 Block
BDL Block gaurd
3 angle valve job
Blox valve train
GSR Cams
550 RC Injectors
t3/t4 57 trim
Ram Horm
81.5 B16 Block
BDL Block gaurd
jdm b16 itr intake manifold skunk 66m tb skunk2 stage 1 cams crower valve springs and retainers je pistons eagle rods golden eagle block gauard golden eagle head studs. str cam seal dcsports cam gears rc autowork ramhorn an 3in dp tial wastegate hks ssbov presicion sc34
i am just gonna throw this out there ...
yes its not a boosted b16a but ,
1990 honda crx hf
b16a
obd1
street tune
ram air intake
xtd stage 4 race clutch
and street tires on 15's
....everything else is OEM
and i am running ...
13.7 - 13.9 == 1/4 mile
1.9 - 2.0 == 60 foot
93 - 96 == mph
what kind of turbo setup is everyone running when some of the times i am reading are not much faster then my STOCK b16a
i just want to know what everyone else is running their b16 in and the turbo setup before i finish my turbo setup and post 11's as my DD
1990 honda crx hf
b16a
obd1
street tune
ram air intake
93 - 96 == mph
Hello everyone!
I live in Finland and my english is very bad. So be nice to me and don't laugh.
This is my first turbo car: Honda Civic -92 (before 1,5i DXi)
Last summer i ride about 500km's with stock block and fueling.
Block:
B16A SiR II not sleeved
Compression 9:1
Wiseco pistons bore 81,5mm
Eagle rods
ACL bearings
Stock OEM crankshaft
Racetech Blockguard
OEM stubs
All seals changes
Head:
B16A2 VTi
Port and polished
Cams Skunk2 Turbo stage2
Adjustable AEM camgears
ARP Headstuds
Headgasket Cometic
All seals changes
Intake:
I broke my original manifold.
Any ideas???
Exhaust:
XS Power manifold
2,5" downpipe
2,5" Catco "racecat" ???
2,5" Invidia G300 Nice sounds
Fueling:
Xenocron fuel pump (copy of the walbro but longer life???)
Original fuel lines
AEM fuelrail
650cc Precision turbo injectors
Copy of Aeromotive fuel pressure regulator
Management:
AEM EMS + wideband
GM 3 bar map
Turbo:
XS Power turbokit (WTF!!!) change includes turbo: holset HX40
I haven't dynoet yet but this autumn or next spring i will.
What kind power i can get in this setup??
Else... I don't remimber..
comments???
Block:
Compression 9:1
Eagle rods
ACL bearings
Racetech Blockguard
OEM stubs
All seals changes
Head:
B16A2 VTi
Port and polished
ARP Headstuds
Headgasket Cometic
All seals changes
Intake:
Any ideas???
Exhaust:
XS Power manifold
2,5" downpipe
Fueling:
Original fuel lines
AEM fuelrail
Management:
AEM EMS + wideband
GM 3 bar map
Turbo:
comments???
00 EM1 b16A2:
cp pistons
eagle rods
ARP head studs
stock head
walbro 255
turbonetics WG
t3t4 60 trim .63 A/r turbonetics
RC 550's
Hondata S200
11PSI
265whp 176ft lbs on 93
8.3@91 mph in the 1/8th on toyo drag radials.... 1.8 60ft....
cp pistons
eagle rods
ARP head studs
stock head
walbro 255
turbonetics WG
RC 550's
Hondata S200
11PSI
Car: DA Integra
Engine: B16a, 9:1 compression, stock sleeves, Skunk2 valvetrain, Skunk2 tuner 1 cams, AEBS intake manifold
Mods: Log manifold, tial 38mm gate, 57 trim t3/t4oe .63 a/r, 3" dp, 3" exhaust, no cat, 2.5" charge pipes, precision front mount, RC 750cc injectors, 3 bar map sensor, walbro 255lph HP pump, Hondata boost solenoid
Tuning on 20 psi on 93 octane: 430 HP / 250 TQ
my Setup
99 Honda Civic Ex
b16a2 Si Swap
ITR Camshafts
NGK Platinum Spark Plugs
Apexi NGK Spark Plug Wires
MSD External Coil
MSD 6al Ignition System
High Flow Cat
JDM Integra Type R 2.3" Exhaust Pipe
Apexi World Sport
STOCK INTERNALS
Custom Precision Turbo Kit
Drag Cast Log Manifold
Precision SC34 Turbine
South Florida Performance Custom Down Pipe
South Florida Performance Custom Intercooler pipe
Ebay Intercooler
GM 3bar Map Sensor
RC 750cc Injectors
Hondata S200 w/ Boost Option, 2Step and Datalogging
Tuned at Tech 3 Performance in NOR CAL
made 238whp and 169tq at 6.5psi
now set at 9psi, hoping to get atleast 280 whp
99 Honda Civic Ex
b16a2 Si Swap
ITR Camshafts
MSD External Coil
High Flow Cat
Apexi World Sport
STOCK INTERNALS
Ebay Intercooler
GM 3bar Map Sensor
RC 750cc Injectors
Car: DA Integra
