B16a Turbo Setups
Old Sep 8, 2009 | 03:37 PM
  #676
Bwhit12's Avatar
Default Re: B16a Turbo Setups
Just wondering what all needs to be redone to the head when wanting to push upper 200's to lower 300. I am going to change cams, but what kind would work best? (I am thinking crower) Should valve and valve springs be changed and if so what should I use? (Don't know to much about them) I think in the block I will go Eagle rods with JE pistons. What bearings are best? And could someone inform me some more on having the block bored?
Old Sep 8, 2009 | 06:19 PM
  #677
90 JDM EF8's Avatar
you dont need to do anything to push upper 200-lower 300 hp...get it tuned right and it will be fine...ive been boosting my totally stock b16 block and head for almost 3 years now with 350 hp and it has been fine...now if your talking 400-500 hp then yea i would recomend building the motor
Old Sep 9, 2009 | 03:29 AM
  #678
Bwhit12's Avatar
Well my car will also double as my dd, so I gotta be super safe and can't be risking anything and I know you have to be pushing the envelope with yours. And what setup would you use if you did build and decided to go higher. How big would you bore out and would you sleeve?
Old Sep 9, 2009 | 10:58 AM
  #679
90 JDM EF8's Avatar
i dont think it would be a problem dd as long as you dont go crazy boosting every gear everywhere you go but if u want to be on the safe side then do it...my tuner told me basically anything over 18lbs on a stock b16 head is pushing it but i keep my boost limit set at 18 lbs so whenever it tries to boost higher the motor shuts down with the hondata so i have no worries...i would sleeve before boring if you want to be safe...good luck with your setup and keep us posted
Old Sep 22, 2009 | 02:46 PM
  #680
Bwhit12's Avatar
MORE!
Old Sep 23, 2009 | 05:23 PM
  #681
robx7fcna's Avatar
Default Re: . (blakkvtec)
Originally Posted by robx7fcna
getting close to finishing up my setup
motor
-81.25 mm
-SRP 8.5:1 pistons
-eagle rods
-block gaurd
-z10 girdle
-Portflow head
-ferrea stainless valves (stock size)
-ferrea springs/ti retainers
-ITR cams
turbo setup
-Borg warner T3/T04E 57 trim
-Ramhorn manifold made by me
-3" stainless downpipe, stainless dumptube, 2.5" alum chargepipes done by me
-Edelbrock intercooler modified to a backdoor setup on hot side
Fuel, ignition and management
-Hondata s300
-MSD pro billet distributor, coil & coil driver
-precision 880s (coming soon)
-Walbro 255lph pump
-aeromotive fuel press reg, -6 lines
hoping for 400whp
the car
UPDATE
FINALLY went to the track for the first time with this setup, did a 12.04 @ 114 on 10 psi (wastegate spring, creaps to 10.6 according to my logs.
might go back this fri to see if I can get an 11!
Old Sep 23, 2009 | 05:34 PM
  #682
b16racereg6's Avatar
^^^ sooo sick man cant wait til march man got mad parts in my closet no time to putem in.....
Old Sep 26, 2009 | 09:38 PM
  #683
DarkVtec EF8's Avatar
Originally Posted by b20beast83
STOCK B16A
Integra Type R Cams
Aeromotive FPR
Walbro 255
Precision 880cc Injectors
6 PSI Garrett T3 T4 60 Trim / .63 Backend
Precision 350HP Intercooler
Cast Manifold
Spooling Performance Intercooler Piping
Tial 38mm Wastegate
Tial 50mm BOV
2.5" DP
B R Fittings Catch Drain back Can Setup
eCtuned
By jdmking, shot with Motorola Phone at 2009-04-17
This car is right hand drive isn't it?
Old Sep 27, 2009 | 07:27 AM
  #684
b20beast83's Avatar
Sure is, and its built now!
Old Oct 15, 2009 | 09:28 PM
  #685
sawilliams1890's Avatar
Default Re: B16a Turbo Setups (hinds90)
really? 11.7 with just a stock b16 turbo and slicks? exactly what setup do you have bc that's where i'm looking to go
Old Oct 17, 2009 | 02:35 PM
  #686
edsihon's Avatar
New Setup
81.5mm B16
CP Pistons
Eagle Rods
BMC race manifold
38mm Tial WG
Super 16g
Ported B16 head
Valves, retainers
aebs IM w/hondata gasket
No numbers yet running on a baseline should be broke in by end of next week
iphone pics sorry for quality
Old Oct 17, 2009 | 05:39 PM
  #687
^^^ plz post numbers man ***** nice....
Old Oct 18, 2009 | 08:51 AM
  #688
johnls's Avatar
my setup is simply 400 at 17psi still have alot left in it when to the track car was falling on its face coming off the line but will go back to get it running good but 11.71 at 122 at 370 hp
its
81.5 srp pistons eagle rod
dual valve springs stock valves
custom turbo manifold
garrett 57 trim 3"dp
stock intake manifold
tial 38 mvs gate tial bov
3" intercooler pipe on cold side 2.5 hot
s300
Old Oct 18, 2009 | 10:18 AM
  #689
^^ sooo sick i like the tegg man god im like wanting spring to come soon so i can boost my stock b16 ... keep us dated ^^
Old Oct 18, 2009 | 11:28 AM
  #690
swapit's Avatar
Here is mine that i just redid a couple months ago:
Old Oct 18, 2009 | 12:46 PM
  #691
johnls's Avatar
will do we have a big race coming up at my local track going to add race gas and try for some 10s
Old Oct 18, 2009 | 01:32 PM
  #692
stalyun's Avatar
garrett 60trim .63 a/r @ 22psi on pump gas
400whp/300wtq @ 8500rpm
tuned by joseph davis
81.5mm
Old Oct 25, 2009 | 12:14 PM
  #693
dont let this thread dieeee
Old Oct 29, 2009 | 07:52 PM
  #694
quicksi69's Avatar
Okie heres my set-up...
Will post dyno up once I hook printer up to this comp.
STOCK JDM 1st gen b16 ( 1989 motor )
318.72 whp & 218.80 wtq DYNOJET Running Cond. 20.45 oC, Humidity 34%
@ 12 PSI !!! ( THIS DYNO WAS DONE WITH ONLY 2.5" EXHAUST,Tial wastegate, and Turbosmart BOV )
Set-up :
Sk2 stg 1 cams, springs,retainers, cam gears ( set 0 - 0 )
FPMotorsports t3/t4 to4e Turbo .50/.63 a/r
STR log manifold ( with crappy elbow )
Small charge pipe kit 2.25", 2.0" and 1 piece 1.75".
FPMotorsports BIG Intercooler
FPMotorsports Tial Style 38mm wastegate ( Had a 38mm tial sold it for the FPMotorsports one )
HKS SSQ style Bov
b&m fpr and gauge
NGK blue wires and stage 7 plugs
Gs-R LSD tranny
Fidanza 8lbs flywheel
Competition Stage 4 6 puck spring clutch kit
2.5" down pipe cut
3" test pipe and full stainless mandrel exhaust
3" vibrant stealth muffler
In a 1994 Honda civic si 2 dr coupe.
(Removed a/c and power steering)
Best Time so far : 13.2 @ 111 MPH ( 2.1')-60' foot
MT ET Drags 22x8x15 @ 14psi ( Gs-R Hammer heads )
I put 50k on this motor, which I purchased from a young 18 yr old punk, and the motor is 100% stock 20 yrs old still ticking....
Plans for next year:
Better manifold : Blox racing ? or a mini ram ?
Bigger IC piping
Fix entire front end suspension ( Tie rod's, ball joints etc )
Get an alignment done with weights on the corners.
Purchasing another jdm block or putting pistons, rods and head studs in this motor.
Goal = 15-16 psi 350whp on 94 Pump Gas.
High 11's constant car.
BIG thanks to :
FPMotorsports ( www.fpmotorsports.com )
Splitfire Performance ( www.splitfireperformance.com )
Old Oct 29, 2009 | 08:07 PM
  #695
GReddy SI's Avatar
motor b16a2 : here is the run down
wiseco pistons 9:1
eagle rods
acl bearings
gsr cams
t3/t4 .57 trim
inline pro manifold
victor x intake manifold
pwr intercooler
550cc rc
70mm tb
3inch dp and exhaust
s200b
i ran a 13.1@107mph with just a drag 3 kit
going to tuning soon. and working on the head
Old Oct 29, 2009 | 09:22 PM
  #696
DaOnE51T's Avatar
Are you guys still running the b16 trans with your boosted setup?
Old Oct 29, 2009 | 09:40 PM
  #697
quicksi69's Avatar
I am running a gs-R lsd and loving it
Old Oct 30, 2009 | 04:44 AM
  #698
blaze the chemi's Avatar
That is awesome man. I like the plug plate that the COP setup sits on. How are you running the ignition?
Old Oct 30, 2009 | 02:42 PM
  #699
hey that comp stage 4 6puck clutch thats what im gona rock on my b16 turbo this spring do u like it for the track? i dont plan on dding my car weekend toy. thats it. and golas are the same as yours 12sec stock head and block... see how long she holds up for... thanks man nice set up tooo
Old Oct 31, 2009 | 04:28 AM
  #700
swapit's Avatar
thanks alot!! the car runs kseries coil packs,aem epm at the dizzy hole,and aem standalone thats it.I gotta thanks jeff evans for the ignition install since he did all that for me.
