B16a Turbo Setups
1993 TEAL EX COUPE, FULLY BUILT B16, HAS EVERYTHING!! PRECISION 61MM, MAXXIN THE TURBO OUT!! MOTOR WANTS MORE! LOL. 680whp ON 32PSI. 1/4 10.9@136. SPINNING 4TH W/SLICKS
all that power and only 10.9? an old setup ran 10.8 at 133 with 480 whp b16..
You're not using any CDI? I thought that the EPM doesn't have the ignitor, only a crank sensor.
I know its just the epm,coils,aem,and 2 relays under the dash.
It looks like I may have to hit Jeff Evans up to see what he did unless you'd like to chime in. That's very interesting since that could really save some cash. I've got the AEM 1010 box myself so I'll have to see what I can do.
a question for you 500-600hp guys. what tranny are u guys running? i got my b16 all built but am clueless about the transmission part. i just dont want to get out to the track and end up breaking something in the tranny cause of the high HP. sorry for the noob question. just getting into the boosted scene.
hi guys, great thread
i currently run a d16, which runs 10.9@132, im considering swapping to a B16, but im unsure whether its worthwhile. im confident i can squeeze 140mph from the D, as im still on stock cam, TB, mani etc, and pump gas, my questions are-
1, how many b16`s have made 145mph+ traps??
2, at 84/85mm, its 1700cc+, which will make more tq, and hp, but how thin are the sleeves at this bore? is it unwise to go so large bore? (not stock sleeves btw).
i know most of the drag guys run b18`s of some sort, but they are expensive, and im not keen on blowing such motors, b16`s are cheap over here though, and seem a better option for trial and error reasons, and im sure it will net more power than the D16, its certainly more effiecent, my d needs a lot of boost and timing to go fast
Do you have a traction bar and LSD? With just 600whp you should be hitting low 10's and maybe with good 60 foots could hit a high 9.
hey that comp stage 4 6puck clutch thats what im gona rock on my b16 turbo this spring do u like it for the track? i dont plan on dding my car weekend toy. thats it. and golas are the same as yours 12sec stock head and block... see how long she holds up for... thanks man nice set up tooo
I just smashed the civic though... soil on the road, bald tires, spun into gardrail....
Coming out this SPRING!!!
Hey this is a question for all your turbo b16 guys. I have a 93 Civic hatch with a PR3 B16a. I want to turbo the car. right now the engine has about 85k on it. How reliable can the car be? It is my only car and it smokes sometimes when I get on it hard. If I run about 10lbs of boost will I be ok? I was probably going to keep the engine stock. Maybe put in some valve springs and a thicker headgasket.
Just make sure your new build includes new piston rings and valve guides...
00 em1
benson 84mm b16a2
cp pistons, crower rods
greddy 18g w/ 31v intercooler
full A/C, & PS
tein type flex coilovers
ITR head
skunk2 pro IM
RC 650's
hondata s300
custom elbow back 3" dp to 3" thermal exhaust
street tuned by me @ 12psi
hp: unknown guess ~300-320
ran 13.3 my first time at the track on stock rims w/ es100's
benson 84mm b16a2
full A/C, & PS
ITR head
skunk2 pro IM
RC 650's
hondata s300
i lost my slip but from memory i wana say it was 111mph. this season im hoping to hit mid-high 12's with my new azeins, better r/t and get the gear based boost dialed in.
