B16a Turbo Setups
Old Feb 18, 2009 | 11:08 AM
  #601
hatchyksp's Avatar
Default Re: B16a Turbo Setups (Mag00n)
Originally Posted by Tchleung
Dusty engine bay from bodyshop
stock b16 arp head studs + bolt ons
270whp/170wtq
what color DA???
looks sick
might think of a sorta similar color on the rex
Old Feb 18, 2009 | 11:37 AM
  #602
RtN08's Avatar
anyone got pics of their set up with the A/C still running?
Old Feb 19, 2009 | 06:11 AM
  #603
ssj155trunks's Avatar
Post Re: B16a Turbo Setups
i have a 18g greddy turboed b16 ef si hatch. im runnin 10psi with rc550cc injectors converted to obd1 p28 ecu chipped with hondata s100 on stock internals. buying everything for the bottom end today should be done in about two weeks and dynoed and tuned around the same time. any suggestions let me know.
-planned work to be done- je forged pistons, h beam eagle rods,comet .05 headgasket,arp headstuds and rodbolts,king bearing kit,obx turbo mani t3 flange with 40mm wastegate to convert from the internal wastegate (no problems with boost kreep yet but dont want any.lol) aiming for 350-400 whp which will seem a lot faster with the 18g do to full boost at low rpm. i will post picks and dyno chart when done.
Old Feb 19, 2009 | 03:36 PM
  #604
90 JDM EF8's Avatar
you should be able to get around 400hp range since your gonna have a built bottom end...i made 350 hp 252tq with my completely stock b16 with external wg 18g with a ramhorn manifold...good luck
Old Feb 19, 2009 | 04:44 PM
  #605
thanx man i actually think ur build is the one that gave me the motivation to go ahead with the 18g. i will post the dyno sheet when im done
Old Feb 19, 2009 | 05:16 PM
  #606
Ek4 SiR's Avatar
Originally Posted by tegman23
Wow I was suprised when I read this I have almost the same setup on 17psi made 380whp 275wtq, I dont think my intercooler was helping though...I was making great power on lower boost, then when I started turning it up while tuning I didnt see very eficent gains...Ebay intercooler...Now I have full-race going for 550whp
what turbo r u running?
Old Feb 22, 2009 | 03:00 PM
  #607
vLad11591's Avatar
i just read almost every single post in this thread. Basically i want to run a turbo for a budget that would make at LEAST 300whp with stock everything. The b16 is basically brand new, with dc headers, short ram, and greddy radiator. in a 93 eg coupe. Can someone give me any ideas of what turbo to buy? Would it be better to do cams, pistons, and then turbo? or could i get more than 300 whp with stock internals stock block/head. Note: the b16 is almost brand new.
Old Feb 22, 2009 | 04:44 PM
  #608
swapit's Avatar
set-up getting redone just waiting for the turbo to get here..
Old Feb 22, 2009 | 07:18 PM
  #609
Silva Bullit DC4's Avatar
^^^ Whats going in it? ^^^
Old Feb 23, 2009 | 08:37 PM
  #610
anybody know what a good headgasket to use for my turboed b16a?
Old Feb 24, 2009 | 08:46 AM
  #611
blaze the chemi's Avatar
OEM headgasket.
Old Mar 30, 2009 | 01:43 PM
  #612
vLad11591's Avatar
bump lets see some setups
Old Apr 3, 2009 | 03:59 PM
  #613
marecco's Avatar
ill have to scam my graph
Stock jdm b16
turbonetics t3/t4 .57 trim
drag manifold
tial 38mm wastegate
2.5 dp and exhaust
580cc injectors
horrible horrible intake that needs replacing
285whp/191lb/ft at 10.5 psi.
Old Apr 3, 2009 | 06:28 PM
  #614
Hobkins's Avatar
Stock jdm b16
drag manifold
tial 38mm wastegate
2.5 dp and exhaust
580cc injectors
That's quite amazing. We almost have exact same setup.
Old Apr 3, 2009 | 06:33 PM
  #615
marcj's Avatar
word
Old Apr 3, 2009 | 07:58 PM
  #616
b20beast83's Avatar
what kind of turbo is that ^^?
what is your boost threashold
Old Apr 3, 2009 | 08:13 PM
  #617
SurferDude905's Avatar
Love your set-up man. I'm in the process of finishing my turbo b16 right now. I just have a question about your catch can set-up. I want to run the lines out of the front of the valve cover. I'm just curious how that set-up works exactly.
I've done some research on it but I can't find the info I'm looking for. Can some of you explain the theory behind it. Also I'm running the Greddy style catch can, so can I still run that set-up?
Thanks
Old Apr 3, 2009 | 09:09 PM
  #618
marecco's Avatar
what kind of numbers are you putting down? my tuner told me that my intake is holding me back big time. currently its like an accordian type plastic? piece. just run because i couldnt get an aluminum pipe made in time. once i get that piece and get a boost control to keep my boost steady throughout the tuner said i should be around 300whp. im not going to push more than that without going inside.
Old Apr 3, 2009 | 10:59 PM
  #619
Hobkins's Avatar
I'm putting on my setup on the 18th so I will have #'s then.
You have stock b16 intake mani? I've heard that's good up to 350 hp... I'm going to upgrade that drag manifold and this 2.5in piping. Both not cheap items to replace but that's what I think is holding back the hp.
Old Apr 4, 2009 | 04:55 AM
  #620
marecco's Avatar
yeah they def arent the best but i have a feeling if i upgrade the manifold as well as put a full 3in exhaust on the car i will be making too much power where i would worry about internals and all. and yeah stock intake manifold stock everything but clutch and turbo kit.
Old Apr 4, 2009 | 05:42 AM
  #621
marcj's Avatar
It's an HX35. Right now my gate opens at 10psi because my clutch is slipping like a pornstars vagoo if I take it any higher. The actual threshold of that turbo is about 25psi and maxes out around 650
Old Apr 4, 2009 | 08:07 AM
  #622
Wytek9's Avatar
is b16b oem rods withstand around 400hp?
Old Apr 4, 2009 | 08:11 AM
  #623
Hobkins's Avatar
Yep if your open up your exhaust and switch out for a decent mani you would be making around 330 on 10.5 psi. Ofcourse that's a rough estimate but close I bet. You could do it on stock internals just leave your boost down. lots of people run 350 on stock internals and much higher.
Old Apr 4, 2009 | 08:18 AM
  #624
marecco's Avatar
yeah i know but i also daily the car minimum of like 50miles a day and im already close to my clutch capacity and if something breaks its bad news haha. once i get a daily i will start doing stuff like that and maybe rip it apart and do some internal stuff. but im happy with my numbers now. i always had a pretty strong one. 158whp with just intake and exhaust back in the day.
Old Apr 4, 2009 | 10:40 AM
  #625
Hobkins's Avatar
Oh I see, well yea I daily to but not nearly 50 miles so running my cm stage 3 isn't to big of a deal and neither is the power.
