B16a Turbo Setups
Old Sep 9, 2005 | 12:05 PM
  #26
hinds90's Avatar
Default Re: B16a Turbo Setups (hinds90)
More I want More
Old Sep 9, 2005 | 12:19 PM
  #27
raene's Avatar
Stock internal B16 with just ARP head studs, running Uberdata 1.70 and DSM 450s. Makes roughly 270 whp with minor boost creep from 7-8.5 lbs or so at redline, I use a 3" dump at the track off the downpipe.
It's run a best of 12.45 @ 112.75 mph hitting the rev limiter (8500) in 4th across the traps, and 12.8 @ 109 mph with the dump closed, running through 2 1/4" exhaust. Of course I use 22" MT cheater slicks. It ran a best of 13.2 @ 110 mph on street tires.
Garrett T3/T04E 57 trim 0.63 a/r, full boost around 4k, spins the tires in 2nd on the street. Tuned to mid to low 11s in a/f at full boost.
Old Sep 9, 2005 | 09:16 PM
  #28
Redline130's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hinds90 &raquo;</TD></TR><TR><TD CLASS="quote">
Would you post your motor setup if you wouldn't mind.</TD></TR></TABLE>
Don't mind at all, here's my list:
B16A (stock bottom, head has ITR/Portflow outer/inner valvesprings, Ti retainers, CTR cams)
ITR intake manifold
stock B16 t/b
Precision SC50
Precision "medium" intercooler
Drag Gen.3 manifold (sucks)
Tial 35mm wastegate
Tial BOV
RC 550cc/min injectors
Fast-turbo oil lines
custom piping
3" down pipe
Walbro 255 fuel pump
NGK BKRE7 plugs
MSD Dig6 w/ SS coil
Accel DFI Gen6
I think that's about it. My entire set-up is here: http://www.redline130.net/dragcrx.html
Old Sep 10, 2005 | 07:10 AM
  #29
lodo1's Avatar
Default Re: B16a Turbo Setups (Redline130)
https://honda-tech.com/zerothread?id=1333980
bone stock b16a with sc61. 299.8 hp and 205.2 tq
Old Sep 10, 2005 | 10:33 AM
  #30
raene's Avatar
11.6 on a stock block... dayam!
What're you using for engine management and how many lbs are you pushing?
Old Sep 10, 2005 | 12:59 PM
  #31
Redline130's Avatar
Default Re: B16a Turbo Setups (raene)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raene &raquo;</TD></TR><TR><TD CLASS="quote">11.6 on a stock block... dayam!
What're you using for engine management and how many lbs are you pushing?</TD></TR></TABLE>
Engine management is an Accel DFI gen 6. Boost is set at 15psi, but creeps to 17~18psi at 8K rpm due to the Drag manifold. Car uses C16 as well. I just need the motor to last one more weekend then it's getting pulled. I'm planning on sending out my spare LS block to get sleeved and built.
Old Sep 10, 2005 | 01:19 PM
  #32
paul93sir's Avatar
81mm bore stock sleeves 60-1 turbonetics turbo rpi racing manifold open downpipe
389@15psi ran 11.2@125
Old Sep 10, 2005 | 01:55 PM
  #33
urbansi's Avatar
Default Re: (paul93sir)
99 si with stock bottem end
18g turbo
310cc injectors
uberdata 1.7
street tuned @ 9psi
214.5 hp, 162 tq
13.6@99.8 with a 2.1 60ft
Old Sep 10, 2005 | 06:45 PM
  #34
Mag00n's Avatar
Default Re: B16a Turbo Setups (turbosi03)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbosi03 &raquo;</TD></TR><TR><TD CLASS="quote">
first time at track best time was 13.004 @ 117mph...
I dont know about that man...that trap should be good for 11's, low 12's at the worste.....
Old Sep 10, 2005 | 06:56 PM
  #35
Tchleung's Avatar
Default Re: B16a Turbo Setups (Mag00n)
Dusty engine bay from bodyshop
stock b16 arp head studs + bolt ons
270whp/170wtq
Old Sep 10, 2005 | 07:33 PM
  #36
Jonny Black's Avatar
Default Re: B16a Turbo Setups (Tchleung)
stock b16 250hp and 184 ft lbs
12.7 so far.
the orginal prototype RpiRacing turbo manifold.
Old Sep 11, 2005 | 01:35 AM
  #37
turbosi03's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mag00n &raquo;</TD></TR><TR><TD CLASS="quote">
I dont know about that man...that trap should be good for 11's, low 12's at the worste.....</TD></TR></TABLE>
definately not 12's at worst bro... I have time slips if you want me to post them
but thanks for good hopes on those numbers
Old Sep 11, 2005 | 02:05 AM
  #38
AlpHaRitEr's Avatar
Well.... here we go, just got the car done and havnt had a chance to do any 1/4 mile runs, gotta find a track out here first...
Stock B16A (for now)
GSR cams
RC 750cc injectors
JG Edlebrock Victor X IM
RPM Service 64mm TB
AEM Cam gears
Turbo XS Dual stage Boost controller
Walbro 255lb HP fuel pump
Full Race Stage 3 (no ac) kit /w 20x11x3 FMIC & dumptube
HASport motor mounts
uhhh i think thats most of it
anywho
tuned with Neptune last week
On the dynopack it put down 300hp and 200lbs, but that was with over 115 degree air,
so we believe out here in california its putting anywhere between 320-350 to the wheels
at 11psi
now.. ill try to post some pics heh
Modified by AlpHaRitEr at 1:23 PM 9/11/2005
Old Sep 11, 2005 | 06:10 AM
  #39
Frozen E's Avatar
H-T White Ops
My baby before she blew up.
Old Sep 11, 2005 | 10:12 AM
  #40
89SiR's Avatar
HEAD:
Crower turbo cams, cam gears, retainers, over sized valves
Eibach valve springs
flow benched head with five angle grind (45% increase in flow)
Block:
stock sleeves, 10 over
JE pistons 8.5:1
Eagle rods
ARP stuff
Z10 block girdle
550cc injectors
msd ignition
Zdyne ecu
Turbonetics T3T4OE 57trim 63AR
LS tranny
12.59 @ 112.9mph 8 psi 2450lbs (untuned) two years ago. I was at 19.9 at idle before it was tuned, lucky I didn't blow it up.
Dyno'd @ 15psi - 379whp & 250tq (tuned) No track time yet.
Modified by 89SiR at 7:40 PM 9/11/2005
Old Sep 15, 2005 | 09:18 AM
  #41
Turbo_Mike's Avatar
Default Re: B16a Turbo Setups (89SiR)
stock b16a
just tuned on chrome (no numbers yet)
9.5 psi
blacktop dsms
walbro 255
gsr cams
t3/t04e 60 trim .60 a/r
2.5" bent downpipe and exhaust
Old Sep 15, 2005 | 10:17 AM
  #42
raene's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89SiR &raquo;</TD></TR><TR><TD CLASS="quote">Dyno'd @ 15psi - 379whp & 250tq (tuned) No track time yet.</TD></TR></TABLE>
Hey Matt You coming out next year? Outlaw cars are getting cocky... gotta show 'em some import lovin
Old Sep 15, 2005 | 10:42 AM
  #43
beaver's Avatar
The times in my sig, setup and pics are in this link
https://honda-tech.com/zerothread?id=1371500
Old Sep 15, 2005 | 11:38 AM
  #44
LostSolVTEC's Avatar
http://forums.evans-tuning.com...=2622
Old Sep 15, 2005 | 11:49 AM
  #45
88crxhfb16's Avatar
Default Re: B16a Turbo Setups (B00STED Si)
[QUOTE=B00STED Si]b16a2 (stock bore, stock sleeves)
stock head??
Old Sep 15, 2005 | 01:14 PM
  #46
swapit's Avatar
Default Re: B16a Turbo Setups (88crxhfb16)
my setup is
b16a 84.5mm golden eagle sleeves
cp9:1,eagle rods
stock b16 head skunk2 springs and ret. type r cams
msd 6a,blaster ss coil,msd wires,
jg edlebrock man. type r throttle body,
aem rail and regulator
255 intank pump
prec 1000cc injectors
big prec. intercooler
fullrace pro street manifold
fullrace 3in downpipe
sc61 turbo .63 ar
on neptune car made 600hp and 420ftlbs on 28lbs
maxed out 3bar map sensor and intank pump
so far the car has gone 11.3 at 129mph traction limited
Old Sep 15, 2005 | 04:56 PM
  #47
eg:R's Avatar
what size intercooler piping are everyone running? what will be a good size for 350+hp? will it be better to run the intercooler piping from the t/b to the factor hole where the stock intake box goes or by the tranny like 94+integra do. this will be on a eg.
Old Sep 15, 2005 | 06:33 PM
  #48
89SiR's Avatar
Hey Matt You coming out next year? Outlaw cars are getting cocky... gotta show 'em some import lovin </TD></TR></TABLE>
hehe, For sure! I just need to throw in the new tranny and get a new clutch. Maybe see you Sunday at that Honda meet.
Old Sep 15, 2005 | 07:24 PM
  #49
ZacCarter's Avatar
Let's make this as big as the ls thread. BUMP!
Old Sep 15, 2005 | 07:58 PM
  #50
*Boostwerks*'s Avatar
This thread gives me hope. I'm looking to make about 300 uncorrected HP up here in CO, and I want to run an 11 all on the stock block.
I think I'm going to go with a 60 trim T3/T4 with the .63 stage 3 turbine. But if I have the $ when the time comes, I might just get a GT30R.
