ARP headstud question please help
Old Apr 25, 2007 | 09:56 PM
Hotori Hanso's Avatar
Default ARP headstud question please help
i have read that 65-75 ftlbs but is that for the nut onto the stud or both the stud into the block and the nut onto the stud? thanks
Old Apr 25, 2007 | 09:59 PM
inspyral's Avatar
You don't torque the studs into the block, they go in "finger tight", which means hand tight with a ratchet or allen/hex key. The torque spec given is for the nut to the top of the stud.
Old Apr 25, 2007 | 11:31 PM
H-T guy's Avatar
Default Re: ARP headstud question please help (Hotori Hanso)
10lbs studs
75lbs nuts
Old Apr 26, 2007 | 01:53 AM
WalkerGSR1's Avatar
The paper that comes with ARP says 70-ft lbs
Modified by WalkerGSR1 at 5:01 PM 4/26/2007
Old Apr 26, 2007 | 11:30 AM
Mentat Ghola's Avatar
Default Re: (WalkerGSR1)
Taylor be careful. Make sure you know what youre doing. Once youre ready to tighten the head on you dont just crank it to 70 ft/lbs. Its a 3 stage torquingprocedure, and you start from the middle and work your way out, theres a specific bolt order. Plus I think the torque spec is a dry spec, clean everything beforehand.
phelpsj2
Feb 13, 2012 03:26 PM
sanman000719
Aug 29, 2010 07:59 PM
thedudefromjerz
Jun 18, 2008 05:07 AM
flip1199
Aug 2, 2005 12:28 PM
B18EG6
Apr 5, 2003 05:19 PM
