AFC Hack premature CEL
Old Oct 23, 2003 | 06:42 AM
dominate9's Avatar
Default AFC Hack premature CEL
I keep throwing a MAP sensor code (code 3) even when I don't pass 11psi. When I'm mashing at 8 psi for a period of time, I throw a code. Why is this happening?
Old Oct 23, 2003 | 07:37 AM
Tinker219's Avatar
Default Re: AFC Hack premature CEL (dominate9)
what are yoursettings?
Old Oct 23, 2003 | 09:15 PM
dominate9's Avatar
Default Re: AFC Hack premature CEL (Tinker219)
1k -10
2-4k -20
5k-8k -25
Old Oct 23, 2003 | 09:17 PM
Johnyquest's Avatar
read one of the 1000 threads on the hack and you'll realize that you need a MINIMUM of -35 to hide boost from the ecu. MINIMUM of -35 @ every setting. TRY AGAIN!
Old Oct 23, 2003 | 10:03 PM
dominate9's Avatar
Default Re: AFC Hack premature CEL (Johnyquest)
My car won't idle right at -35. I have to put it to like -10 to -15 at 1k for it to idle. So I just set the other accordingly. I'll leave the 1k where it is and set the others to -35 and see if that works.
Old Oct 23, 2003 | 10:06 PM
racinskittle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Johnyquest &raquo;</TD></TR><TR><TD CLASS="quote">read one of the 1000 threads on the hack and you'll realize that you need a MINIMUM of -35 to hide boost from the ecu. MINIMUM of -35 @ every setting. TRY AGAIN!</TD></TR></TABLE>
Haha i never new that Just kept it that way cuz it was too rich when i went below that ha.
Old Oct 23, 2003 | 10:42 PM
rjardy's Avatar
Default Re: AFC Hack premature CEL (racinskittle)
OBD1 or OBD2?
Rob
Old Oct 23, 2003 | 11:19 PM
Mr. Softee's Avatar
Default Re: AFC Hack premature CEL (rjardy)
do you know how the afc hack works
Discosteak
Nov 2, 2005 07:38 AM
SOHCex20
Aug 18, 2005 08:49 AM
silverCRXTC
Feb 4, 2004 07:32 AM
dpine
Jan 15, 2004 04:20 PM
