afc hack CEL and limp mode in third gear, sohc
Old Oct 29, 2005 | 10:00 AM
Discosteak's Avatar
Default afc hack CEL and limp mode in third gear, sohc
like the title says about halfway through third my CEL comes on and the car goes into limp mode. any ideas i belive the CEL is for map sensor but i havent checked it in a while. any help is appreciated
Old Oct 29, 2005 | 10:03 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: afc hack CEL and limp mode in third gear, sohc (BADEG4)
well first off you need to check what the code is, and then we can go from there.
Old Oct 29, 2005 | 10:13 AM
Discosteak's Avatar
Default Re: afc hack CEL and limp mode in third gear, sohc (boostedcivicsir)
code 1 and 3 and im betting its not code 1 putting it into limp mode
Old Oct 30, 2005 | 04:46 AM
Discosteak's Avatar
bump
Old Oct 30, 2005 | 05:08 AM
USDM 4G VTEC's Avatar
code 1 is the oxygen sensor... time to get a new one
and the code 3 is the MAP sensor and thats the one that trows u on limp mode
u either have to low of settings on the VAFC.. like -29% or so or u are boosting 10+psi
Old Nov 1, 2005 | 09:08 AM
Discosteak's Avatar
Default Re: afc hack CEL and limp mode in third gear, sohc (USDM 4G VTEC)
im at like -19 at full boost and its at 7 psi
Old Nov 1, 2005 | 10:28 AM
99lspwr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BADEG4 &raquo;</TD></TR><TR><TD CLASS="quote">im at like -19 at full boost and its at 7 psi</TD></TR></TABLE>
Anything below -35 at 10-12 psi and up will put the car in limp mode....You should be no where near -19 under boost with 440s...
Old Nov 1, 2005 | 06:25 PM
Blaze45's Avatar
Brrraaaap!
Default Re: afc hack CEL and limp mode in third gear, sohc (99lspwr)
Change your in and out settings to -6 and -6. That should do it.
Old Nov 1, 2005 | 07:10 PM
havok hybrid's Avatar
Default Re: afc hack CEL and limp mode in third gear, sohc (Blaze45)
just tuned a 8 psi t3 b16 a on the dyno with a vafc last week... set the base timing to 18 degree. pull the vafc down to -45ish from 4500 to redline.. below 4500 set it to 35-8...
turn the fuel presure up to like 55 with vacuum off... see what that will do for you ..
Old Nov 1, 2005 | 07:12 PM
put the settings at around -30 on full boost, run it on 3rd and tell me if still there
Old Nov 2, 2005 | 07:27 AM
Discosteak's Avatar
it idles with the afc set at -32 anyhting below and it idles like expletive
Old Nov 2, 2005 | 07:38 AM
thermal's Avatar
-19 is too rich. The richer you go on the set-point, the more you become prone to CEL due to the map curve.
silverboost
Sep 28, 2005 02:30 PM
SOHCex20
Aug 18, 2005 08:49 AM
Preferio
Jul 6, 2005 08:56 AM
ILLICON3000
Aug 4, 2004 03:25 PM
kaj
Sep 27, 2003 09:36 AM
