AFC-Hack obd2 and timing question
Old Jun 3, 2004 | 02:52 PM
PrecisionH23a's Avatar
Default AFC-Hack obd2 and timing question
Those of you running the afc-hack with an obd2 set-up, what are you using to control your timing since changing the position of the distributor on an OBDII car won't change the timing?
I know the BTM's work but the car I am working on this weekend does not have one. I know the hack tends to advance timing in 5th gear so how safe is it to run it with no BTM? Should I just run the FMU set-up until he gets a hondata in a month or two?
Old Jun 3, 2004 | 03:03 PM
civicshowracing65's Avatar
Default Re: AFC-Hack obd2 and timing question (PrecisionH23a)
i'm running nothing on my obd-2 afc hack. Runs fine without any detonation
Old Jun 3, 2004 | 06:47 PM
BB6-213's Avatar
Bump, I would like to know also.
Old Jun 3, 2004 | 07:03 PM
Default Re: (BB6-213)
So should I run the hack with 7 psi on a h23a with 440cc injectors or instead run the fmu and s-afc?
This motor will have hondata in about 3-4 weeks. I'm worried about running zero timing retard in 5th gear pulls where the hack advances timing.
Old Jun 3, 2004 | 07:24 PM
ki11a8ee's Avatar
Default Re: (PrecisionH23a)
make sure u tune it with the hack cause if u dont u end up like i did with all four ringlands cracked. just drive the car like ur breaking it in.
Old Jun 3, 2004 | 08:06 PM
MachAF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a &raquo;</TD></TR><TR><TD CLASS="quote"> since changing the position of the distributor on an OBDII car won't change the timing?
thats not true. Where did you find this information?
Old Jun 3, 2004 | 09:17 PM
Default Re: AFC-Hack obd2 and timing question (MachAF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MachAF &raquo;</TD></TR><TR><TD CLASS="quote">
thats not true. Where did you find this information?</TD></TR></TABLE>
http://www.boosted-hybrid.com/...=hack
Old Jun 4, 2004 | 03:28 AM
integrx's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a &raquo;</TD></TR><TR><TD CLASS="quote">since changing the position of the distributor on an OBDII car won't change the timing?
it should. At least it says it does in the haynes. well, it don't mention anything abour obd1 or obd2, nor does it say anything about for 94-95/96+ but it tells you to jump the severice check connector, and turn on car then rotate the distributor until timing is correct.
Old Jun 4, 2004 | 04:44 AM
Joseph Davis's Avatar
http://www.boosted-hybrid.com/...=hack</TD></TR></TABLE>
Cool... I had to get an account there to correct their bad information. Despite the OBD2 timing problem, I can't recommend a BTM due to the expense... you can get a real EMS for less.
Old Jun 9, 2004 | 06:01 PM
BB6-213's Avatar
Default Re: AFC-Hack obd2 and timing question (integrx)
Has anybody actually tried this on an OBD2 car, and know if it works?
Old Jun 9, 2004 | 06:32 PM
thermal's Avatar
Default Re: AFC-Hack obd2 and timing question (BB6-213)
Yes, I have. I was running 10 psi on a P2P ECU (OBD2b) on my 99 civic EX. **** sucked. It kept popping a CEL code 13 (barometric signal) and would sometimes stutter on the mid RPM band. I got rid of the P2P and replaced it with a P28 (OBD1). It runs wayyyyy better now and no CEL....
As far as adjusting timing on OBD2, I'm positive that it can be done on the distributor as well......
TeamCracka
Jul 2, 2004 04:37 PM
tolowhb
Feb 21, 2004 10:24 AM
boost fed ls
Aug 11, 2003 08:26 AM
B_1_8_hatch
Jul 28, 2003 01:33 PM
TurboDC4
Feb 7, 2003 02:29 PM
