detonation while using afc/hack
Old Aug 10, 2003 | 02:59 PM
boost fed ls's Avatar
Default detonation while using afc/hack
I have been reading that when you use the afc/hack the ecu will think you are running lean and advance the timing. Can u run stock timing if you are going to run between 5-8psi? Any one with a boosted ls using the afc hack keep stock timing?
Old Aug 10, 2003 | 03:00 PM
DA-MAX's Avatar
Default Re: detonation while using afc/hack (jdm2916)
why not just retard the timing a few degrees at the distributor??
Old Aug 10, 2003 | 03:13 PM
Daniel's Avatar
Default Re: detonation while using afc/hack (DA-MAX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA-MAX &raquo;</TD></TR><TR><TD CLASS="quote">why not just retard the timing a few degrees at the distributor??</TD></TR></TABLE>
Yeah, that's what I did when running the hack. I was told that at 7 psi, I could get away with only retarding maybe 1 or 2 degrees, but I went ahead and did -3. Robbed me of a lot of power, but I knew I was safe that way. Never detonated from the looks of my plugs, but they showed signs of running rich as hell.
Old Aug 10, 2003 | 03:18 PM
Default Re: detonation while using afc/hack (Daniel)
you can still do this on an obd2 car? and what direction (to the front or the rear of the car) do you turn the dizzy to retard the timing?
Old Aug 10, 2003 | 03:27 PM
Daniel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm2916 &raquo;</TD></TR><TR><TD CLASS="quote">you can still do this on an obd2 car? and what direction (to the front or the rear of the car) do you turn the dizzy to retard the timing?
Yeah, still works on OBDII. Retard is clockwise, so that would be turning the distributor towards the front of the car.
Old Aug 10, 2003 | 03:32 PM
thanks man
Old Aug 10, 2003 | 06:42 PM
scttydb411's Avatar
i don't have ls, but i do have obd2 d16y7. i just have my timing handled by msd btm....1/3degree per 1psi. not quite 3 degrees of retard at 9psi and i don't seem to have any detonation.
Old Aug 10, 2003 | 06:53 PM
TraKtioN's Avatar
Default Re: (scttydb411)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scttydb411 &raquo;</TD></TR><TR><TD CLASS="quote">i don't have ls, but i do have obd2 d16y7. i just have my timing handled by msd btm....1/3degree per 1psi. not quite 3 degrees of retard at 9psi and i don't seem to have any detonation.</TD></TR></TABLE>
The dsm btm is for v10s though?
Old Aug 10, 2003 | 07:00 PM
DA-MAX's Avatar
Default Re: (TraKtioN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TraKtioN &raquo;</TD></TR><TR><TD CLASS="quote"> the dsm btm is for v10s though? </TD></TR></TABLE>
its MSD
and they do make a universal unit for all cars and also one that comes combined with the 6Al ignition box,
Old Aug 11, 2003 | 08:26 AM
toxicshit's Avatar
so the ECU will advance your timing enough when you want to run 7 psi ???
TeamCracka
Jul 2, 2004 04:37 PM
integraracer94
Jun 3, 2004 02:02 PM
X2BOARD
10
Apr 8, 2004 05:18 AM
nigel
Aug 23, 2003 10:32 AM
BorderM3
Dec 30, 2002 11:40 AM
