** The E85 Thread **
Send me a valve cover and i can do one like you want
I bet your car weighs like 2400-2500lbs with driver... damn hatch's are light... im jealous! my friends LST hatch weighs 2350 with driver...he can make 340-350whp and trap the same as me making 50-60whp more
Yeah i will shurly let you know how it goes friday night!
....Yeah i will shurly let you know how it goes friday night!
aaa **** my bad
... Still the coupes arent that much heavier, my friends coupe with a turbo b16 and him in it weighs 2400 even, and thats with power windows and a sunroof.. i was amazed it was that light... i need to put my damn car on a major diet!
GSR-T WTF did you do to make your teg down to that weight? is it a GSR chassis? you have a sunroof? doo tell
... Still the coupes arent that much heavier, my friends coupe with a turbo b16 and him in it weighs 2400 even, and thats with power windows and a sunroof.. i was amazed it was that light... i need to put my damn car on a major diet!GSR-T WTF did you do to make your teg down to that weight? is it a GSR chassis? you have a sunroof? doo tell
Well for starters....
DC2 chassis, no front bumper support, no a/c, no ps, no ABS, no heater (wiring removed too), no sound deadening, no rear wiper or antenna, no wing, all un necessary wiring removed, lighter LCA's, light wheels etc. Honestly turbo stuff does not add that much weight, my ramhorn and turbo weight as much as my stock exhaust manifold, I had 43lbs of sound deadening in the car. I have all my interior in minus the rear seats and the hatch cover, so you cant tell at all besides the obvious, I hate a "gutted" car.
This year the sunroof will be gone, adding 4" AL exhaust, I will have 2 lightweight seats, a carbon hood and trunk, no rear support but I am adding all the safety **** (cage, net, chute, kill switches, catch pan, scatter shield etc)
Damn thats alot of ish to remove... Well since this is my DD there are some things id like to keep. One main thing is the HEATER! i grew up in the tropics and i like to be warm and winter here is COLD!
i know for a fact the heater core and stuff weigh a good 30-40lbs.. i guess if i was to really get into taking stuff out i could go crazy but some things i still want to keep.... i think i will eventully get rid of both bumper supports, PS, rear wiper delete and maybe some sound deadening.... unless i turn this car into a weekend car, then id take out all the **** i dont need!
I had the heater in until just a month ago, my car is a full street car but its has to go to the next level now. I like to drive my car in the cold but its just plain useless anymore, I need a C02 setup to set the boost at 3psi or its just a tire blaze fest. I know I pick up 50hp in the cold air I run out of duty cycle at 20psi and the tire situation is just comical, I can blaze 5th gear to redline on the highway just messing around
I've been doing a lot of E85 the last couple months. Recently been doing a little E98 as well. For the price and benefits I love this stuff. The E85 I have picked up quite a bit mid range meaning better spool time. We just picked up 432 gallons of E98 yesterday
See what we can do with that. I will post back
See what we can do with that. I will post backThe shop i go to is a big fan of E98!! they have made 900+whp on it!
Well i went to the dyno today again! Lets just say im alot more happy with the current numbers....I knew what the problem was before and its my dumptube... its short and on the dyno its sucked back up but on the street while the car is moving it doesnt have that problem... So i put a fan ontop of the manifold and did a WG pass... did 343whp@10.5psi... 2nd pass was 389@13.5psi... 3rd pass was the good one
421whp@14.5 psi Datalog showed a peak of 14.6psi.... the 421whp was STD SAE it did 409whp....the dyno tq pickup was not working so i dont know how much torque i made which bites but o well... last night we did a 16psi pull and it felt really good... so im thinking @ 16psi i would make about 440-450whp.. but idk for sure... The timing is still conservitave i think... @ 16psi at the top of 4th timing was 16 deg @ 8000rpm... AFR's were about 11.5-11.7... Needless to say im pretty happy and im ready for the track to open on friday!!! hahahaill have the graph up tomorrow if i can get to it!
The 700whp I mentioned was with a DSM
Congrats on the new numbers!!!
thats still a **** load!! the 900whp+ cars were DSM's tho
ooo hahaha sorry i didnt know it was also a DSM
What turbo does that DSM have?
And thanks man!! im pretty happy with them.. The only thing i have changed since my last 374whp was ITR cams... I will have the graph up tomorrow... ITR cams made a hugeeee difference!!!
What turbo does that DSM have?And thanks man!! im pretty happy with them.. The only thing i have changed since my last 374whp was ITR cams... I will have the graph up tomorrow... ITR cams made a hugeeee difference!!!
Very nice Gringo, do you happen to have the ability to overlay your 2 graphs to show the power increase of the cams throughout the powerband?
I cant wait to put some cams in my car, considering the power I made with GSR Cams I would think I could pick up an easy 50hp at the same boost level with ITR's, cant wait to slap on the Pro-1's.
I saw alot of rah rah recently about E85 messing up someone's intake ports, well I just pulled my IM off and I will post pics tomorrow of the ports, they look exactly like they did when I got the head back from the machine shop, minus a little crud on valves.
had mine off and didn't notice anything, either. bunch of B.S.
And yes i can overlap the graphs i will have one up tomorrow..
All that BS about E85 is true BS... when i took off my head last week i as shocked at the condition it was in.. there was very very little carbon build up on the piston tops and the intake valves were clean as FAWK!!
Track opens tomorrow night... my perdictions are 126-127 trap and if the track is hooking 11.2-11.3.
hmmmm...i dont see how you wouldnt see results at the track. he gained power.
if you had some cams that just changed the power band i could see how it would be hard to notice that at the track but myles made 40+ wheel. by the rule of thumb isnt that 4 tenths? 10whp = .1 sec?
Im dead possitive that the car will go faster, if it doesnt ET faster it will shurly Trap higher..
And no i dont think that rule of thumb is too accurate.. Youd have to be able to make all that extra power Hook for that statement to be correct.. i calculated that at the speed im going now every 12-15hp i pick up seems to be close to about 1mph... so id say ET is more dependent on your suspension and how you can put the power down, and Trap speed = raw power... thats how i look at it
