Continuity????
Old Aug 15, 2007 | 09:19 PM
xXSilentScreamXx's Avatar
Default Continuity????
ok so im throwing CEL CKP so i checked the dizzy.....good
so now i need to check the ecu i did but idk what it means
ok
c2=ckp power
c12=ckp ground
now i tested the wires for shorts like this
c2-chassis = no continuity
c12-chassis= continuity??
which one has a short???
after i rev to like 3500 rpms my motor ***** on itself
Old Aug 15, 2007 | 10:28 PM
Default Re: Continuity???? (xXSilentScreamXx)
bump
Old Aug 15, 2007 | 11:30 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
no on is going to have any ideal of what you are talking about. No model of the car, No blue prints to or diagram of the harness.
Old Aug 15, 2007 | 11:42 PM
Default Re: Continuity???? (wrx-killer-Sti-eater)
ok its a 96 ek hb with a h22 obd1 motor
im checking the ecu to see if im getting a signal b/c i checked the continuity on the ckp and its fine so there is a short in one of the wires
Old Aug 15, 2007 | 11:46 PM
if i use a milti meter to check continuity
if i touch the power wire* for the ckp* and the car i get no continuity
but if i touch the ground *for the ckp* and car i get continuity?
Old Aug 16, 2007 | 05:42 AM
fcm's Avatar
fcm
Old Fart
The power wire should have no continuity to ground, [cars chassis]
The the ground should have full continuity to ground, [as it is a ground]
There is no short to ground on the power lead, and the ground lead should be grounded, as it is. 94
Old Aug 16, 2007 | 11:03 AM
Default Re: Continuity???? (fcm)
https://honda-tech.com/zerothread?id=1310561
this guy has the same problem as me
Old Aug 16, 2007 | 11:45 AM
fcm's Avatar
fcm
Old Fart
Yea, it would have been nice if he had told us where the short was.
I would assume it is in the wiring from the CKF, [Crankshaft Fluctuation Sensor] the pulse rotor is mounded at the front end of the crank shaft, and the pickup sensor is mounded to the engine next to the rotor.
You can fallow the lead from the sensor to the plug, [remove timing cover] unplug the sensor, set meter to impedance and touch probes to the 2 outer terminals of the plug going to the sensor, [not the middle terminal] impedance should be 1.6-3.2 K ohms, if not replace the sensor, [94-98 Integra and 96-98 Civic] you can also check continuity to chassis ground on the two outside terminals, [again, not the center terminal] if there is continuity, replace the sensor.
What is the h22 obd1 motor out of?
Above specs may not apply to it? 94
Old Aug 16, 2007 | 01:55 PM
https://honda-tech.com/zerothread/2072492
this will xplane everything
Old Aug 16, 2007 | 03:36 PM
B18C_EJ8's Avatar
And just what does this have to do with audio, security or video?
Old Aug 16, 2007 | 04:26 PM
Default Re: (B18C_EJ8)
its electrical
Old Aug 16, 2007 | 04:37 PM
B18C_EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">And just what does this have to do with audio, security or video? </TD></TR></TABLE>
.adam.
May 26, 2025 06:09 PM
mattm868
Sep 21, 2007 09:35 PM
xXSilentScreamXx
10
Aug 16, 2007 11:37 AM
10seceg
Jan 26, 2004 08:53 AM
coldfiremx
Jan 14, 2004 05:37 PM
