CoNTiNuItY????
CoNTiNuItY????
ok so im throwing CEL CKP so i checked the dizzy.....good
so now i need to check the ecu i did but idk what it means
ok
c2=ckp power
c12=ckp ground
now i tested the wires for shorts like this
c2-chassis = no continuity
c12-chassis= continuity??
which one has a short???
after i rev to like 3500 rpms my motor ***** on itself
ok
c2=ckp power
c12=ckp ground
Re: CoNTiNuItY???? (xXSilentScreamXx)
If you unplugged the distributor from the main harness, as well as the ECU, and you measure 'continuity' from one of those wires to ground, that wire is shorted to ground.
a short to ground is power straight to ground without a load which would burn the wire out or blow a fuse or melt a link or pop a breaker if your ground got shorted to another ground it wouldnt make a differance. If you measure voltage in a ground wire that means there is prob. resistance in the circuit on its way to ground.
civbeater90
10
11-28-2002 07:04 AM
