Tippyman's Project Thread
Old Dec 6, 2006 | 08:48 PM
  #826
STREETWERKZ's Avatar
Default Re: (Tippyman)
video time.
Old Dec 7, 2006 | 08:54 PM
  #827
1990si's Avatar
Default Re: (STREETWERKZ)
agreed
Old Dec 8, 2006 | 02:29 PM
  #828
Tippyman's Avatar
Default Re: (1990si)
<U>***UPDATE 12/8/06***</U>
I tested the nitrous tonight. Holy ******* shitty monkeyballs. I almost blew the bitch up.
My only guess is the the fuel soldenoid somehow did not kick on. I sprayed in second, it revved to about 5k, and wouldn't go any higher. When I backed off, it died. I let the clutch out and it started again (Like you were push starting it.) but ran like ***. I pulled over, yanked the plugs, and look what I saw:
Cylinder 1:
(Yes, that is the ground strap TOUCHING the electrode!!!)
Cylinder 2:
Cylinder 3:
Cylinder 4:
As you can see, I must have been detonating pretty damn hard because it blew the ground straps clear off! The only reason that cyl. 1 didn't blow off I am guessing is because it's the furthest away from the TB.
I limped it home and threw my old NGK's in and she runs perfectly. Guess it wasn't detonating long enough to **** the pistons up.
The only thing I can think of is that the fuel soldenoid didn't activate, and I sprayed a 75 shot of nitrous with no fuel to compensate. The old plugs, when I pulled them out, were really brown cause I am running rich due to the timing retard and PG7 ECU. So I know it wasn't running lean before. I was also running 104 octane fuel!
I am going to go over the fuel soldenoid wiring tomorrow and check to see if anything is amiss. After the one-over, I'll test it by just spraying it into the air to see if fuel comes out. I'm making sure it is spraying plenty of fuel before trying again...
Old Dec 8, 2006 | 02:47 PM
  #829
george34's Avatar
WOW! Do you have to find a way to get the ground straps out of the engine now? or do you just leave them in there and they will break up and come out with the next oil change?
Old Dec 8, 2006 | 02:48 PM
  #830
Tippyman's Avatar
Default Re: (george34)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by george34 &raquo;</TD></TR><TR><TD CLASS="quote"> WOW! Do you have to find a way to get the ground straps out of the engine now? or do you just leave them in there and they will break up and come out with the next oil change?</TD></TR></TABLE>
The only reason the ground straps aren't on there is because they vaporized. The pressure and heat from detonating is so immense that they disintegrated.
Old Dec 8, 2006 | 03:01 PM
  #831
Turbogixxer's Avatar
Just because the motor runs, does not mean it did not do damage. Check it over again.
To a dry test of the nitrous system (no fuel pressure, no nitrous pressure) and see if everything is working.
You have a fuel safetly switch?
Old Dec 8, 2006 | 03:04 PM
  #832
george34's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">
The only reason the ground straps aren't on there is because they vaporized. The pressure and heat from detonating is so immense that they disintegrated.</TD></TR></TABLE>
Oh I was thinking that the tip chipped off.
By the way nice project.
Old Dec 8, 2006 | 03:06 PM
  #833
Ross 2.0's Avatar
In a Junkyard near you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STREETWERKZ &raquo;</TD></TR><TR><TD CLASS="quote">everytime i see tippy post, i rush in here thinking im gonna see.....
" guys, i blew it up "
LOL! </TD></TR></TABLE>
why didn't you call?
Old Dec 8, 2006 | 03:07 PM
  #834
Tippyman's Avatar
Default Re: (Turbogixxer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbogixxer &raquo;</TD></TR><TR><TD CLASS="quote">
You have a fuel safetly switch?</TD></TR></TABLE>
No, I don't. I am getting plenty of fuel to the soldenoid, I know that. I just don't think it turned on.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbogixxer &raquo;</TD></TR><TR><TD CLASS="quote">Just because the motor runs, does not mean it did not do damage. Check it over again.</TD></TR></TABLE>
It runs great and revs fine. I'ma go take it for a quick spin right now just to be sure.
Old Dec 8, 2006 | 03:09 PM
  #835
It runs great and revs fine. I'ma go take it for a quick spin right now just to be sure.</TD></TR></TABLE>
Trust me. It may run fine now. That is hard knock, check the motor before you spray again
Old Dec 8, 2006 | 03:11 PM
  #836
Tippyman's Avatar
Trust me. It may run fine now. That is hard knock, check the motor before you spray again </TD></TR></TABLE>
How can I check the motor? Tear down?
Old Dec 8, 2006 | 03:15 PM
  #837
How can I check the motor? Tear down? </TD></TR></TABLE>
Compression and leakdown test.
  #838
Tippyman's Avatar
Compression and leakdown test. </TD></TR></TABLE>
I bought one.
Old Dec 8, 2006 | 05:40 PM
  #839
1990si's Avatar
who cares what happened to the motor. how did the nawwwzz feel man?
Old Dec 8, 2006 | 05:42 PM
  #840
Tippyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1990si &raquo;</TD></TR><TR><TD CLASS="quote">who cares what happened to the motor. how did the nawwwzz feel man?</TD></TR></TABLE>
Lol. **** you.
My brother said "Woah, did you feel that?"
I said "Yeah, look at the tach." (Reading 0)
He says, "Oh."
Old Dec 8, 2006 | 05:48 PM
  #841
SomeDude56's Avatar
Lol. **** you.
He says, "Oh." </TD></TR></TABLE>
Lol, Dude did you just fe....KABOOOOMMMMMMMMMMMM
Old Dec 8, 2006 | 05:57 PM
  #842
Tippyman's Avatar
Default Re: (SomeDude56)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SomeDude56 &raquo;</TD></TR><TR><TD CLASS="quote">
Lol, Dude did you just fe....KABOOOOMMMMMMMMMMMM </TD></TR></TABLE>
I was smart and didn't stay on it, so nothing went kaboom.
I am so pissed off that this is an incredibly safe setup (that I spent alot of money and time on) and it's still ******* up.
I suppose if it was just a soldenoid issue, then everything is ok...
Old Dec 8, 2006 | 06:15 PM
  #843
Got_soy's Avatar
whats up with the sig? did you kill it?
Old Dec 8, 2006 | 07:24 PM
  #844
Tippyman's Avatar
Default Re: (Got_soy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Got_soy &raquo;</TD></TR><TR><TD CLASS="quote">whats up with the sig? did you kill it?</TD></TR></TABLE>
Nah, I just decided I wanna build one with rods/pistons, lightly built head so that when the motor is finished, I can just swap it in and not have any down time.
Direct port in the future
Old Dec 8, 2006 | 10:25 PM
  #845
KillSwitch's Avatar
I suppose if it was just a soldenoid issue, then everything is ok...</TD></TR></TABLE> ive experimented with nitrous on my crx a while back and let me tell you that you might have to tear the soldenoids down and lube them up with white lithium grease because they like to stick sometimes... just my thoughts
Old Dec 9, 2006 | 12:54 PM
  #846
Tippyman's Avatar
Default Re: (KillSwitch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KillSwitch &raquo;</TD></TR><TR><TD CLASS="quote"> ive experimented with nitrous on my crx a while back and let me tell you that you might have to tear the soldenoids down and lube them up with white lithium grease because they like to stick sometimes... just my thoughts</TD></TR></TABLE>
Thanks.
I did a comp. test today. Looks like I'm ok.
Old Dec 9, 2006 | 04:52 PM
  #847
EF Sedan Enthusiast's Avatar
wow, good thing the track was closed. hopefully you can get the problem figured out. glad to know your motor wasn't damaged to bad.
Old Dec 9, 2006 | 09:36 PM
  #848
Tippyman's Avatar
Default Re: (jdm_ef3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_ef3 &raquo;</TD></TR><TR><TD CLASS="quote">wow, good thing the track was closed. hopefully you can get the problem figured out. glad to know your motor wasn't damaged to bad. </TD></TR></TABLE>
Yeah, just a few bucks worth of NGK's.
I am gonna go over all the wiring tomorrow and before I spray again, make sure fuel is shooting out of the nozzle.
I'm gonna re-check everything, and then take off the intake. Then, with the bottle off, spray it into the air, just to see if fuel sprays out. If so, then we're in business. If not, I get pissed off.
Old Dec 10, 2006 | 12:02 AM
  #849
ZBracing's Avatar
lucky
Old Dec 10, 2006 | 06:52 AM
  #850
SomeDude56's Avatar
Default Re: (ZBracing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZBracing &raquo;</TD></TR><TR><TD CLASS="quote">lucky</TD></TR></TABLE>
Great first post, way to contribute
