Tippyman's Project Thread
Old Nov 14, 2006 | 06:45 PM
  #576
zccr-xsi's Avatar
u sparying a zc?
Old Nov 14, 2006 | 06:47 PM
  #577
Tippyman's Avatar
Default Re: (zccr-xsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zccr-xsi &raquo;</TD></TR><TR><TD CLASS="quote">u sparying a zc?</TD></TR></TABLE>
Yes sir.
  #578
STREETWERKZ's Avatar
read much?
  #579
zccr-xsi's Avatar
DOHC?
Old Nov 14, 2006 | 06:49 PM
  #580
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zccr-xsi &raquo;</TD></TR><TR><TD CLASS="quote">DOHC?
your computer only reads braile? :..: . : :: .:::. :. : ?
read the thread. hell, just the first page.
there are pictures too.
Old Nov 14, 2006 | 06:50 PM
  #581
Tippyman's Avatar
Look at the very first post in this thread. It will reveal all...
Old Nov 14, 2006 | 06:52 PM
  #582
Autoworks's Avatar
Default Re: (STREETWERKZ)
:..: . : :: .:::. :. : ? = SOHC ZC in braile...learn something new everyday
Old Nov 14, 2006 | 06:53 PM
  #583
Default Re: (Autoworks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Autoworks &raquo;</TD></TR><TR><TD CLASS="quote">
:..: . : :: .:::. :. : ? = SOHC ZC in braile...learn something new everyday </TD></TR></TABLE>
Old Nov 14, 2006 | 06:58 PM
  #584
zccr-xsi's Avatar
thats all i want to know is what can i use other then the box zex sent me for my zc?can i still use turbo edit?what do u suggest.ill only be doing 50 maybe 55 the most.(only at the track)
Old Nov 14, 2006 | 07:05 PM
  #585
Tippyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zccr-xsi &raquo;</TD></TR><TR><TD CLASS="quote">thats all i want to know is what can i use other then the box zex sent me for my zc?can i still use turbo edit?what do u suggest.ill only be doing 50 maybe 55 the most.(only at the track)</TD></TR></TABLE>
For a 50 shot on a ZC? I'd retard timing one degree, run 93 octane fuel only, and put in some new plugs. Make sure you're fuel filter is new and you're golden.
That's all you really need. there's other stuff you could so if you're paranoid like me...
Old Nov 14, 2006 | 07:09 PM
  #586
zccr-xsi's Avatar
im just wonder is it even safe to cut and spice into your fuel line.cant u just use t fiting from fuel filter. i bought the same plugs u got.got like 4 boxes so when i go to track.can i use a msd btm to retard the timing?i always run 93 no matter what.my zc dont like mid grade or regular gas.got brand new fuel filter, and getting same fuel pump u have here soon.the motor runs strong as **** i know it can handle it with no porb. just lil worried about the clutch holding,and the single cam si tranny.
Old Nov 14, 2006 | 07:21 PM
  #587
Tippyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zccr-xsi &raquo;</TD></TR><TR><TD CLASS="quote">im just wonder is it even safe to cut and spice into your fuel line.cant u just use t fiting from fuel filter. i bought the same plugs u got.got like 4 boxes so when i go to track.can i use a msd btm to retard the timing?i always run 93 no matter what.my zc dont like mid grade or regular gas.got brand new fuel filter, and getting same fuel pump u have here soon.the motor runs strong as **** i know it can handle it with no porb. just lil worried about the clutch holding,and the single cam si tranny.</TD></TR></TABLE>
What do you mean about the fuel line? Do you have a wet kit? I'm not sure about the ZEX, but my NX kit came with a "T" fitting that goes into your fuel line. It's perfectly safe.
I don't have any experience with the MSD timing controller. I did a little research, but I would rather KNOW my engine is properly retarted because I did it under the hood. What if the MSD thing breaks or you wire it wrong?
You're clutch might not hold, that's a legitimate issue with nitrous. I'm using a Centerforce Dual Friction clutch, I'm hoping it'll hold.
Don't worry about the Si tranny, I'm using it, it can handle 200 whp no prob. The differentials in them aren't the strongest things in the world, but assuming you preload properly and don't just dump the clutch all the time, you'll be fine.
Old Nov 14, 2006 | 07:29 PM
  #588
zccr-xsi's Avatar
Default Re: (Tippyman)
ok i thought u had to cut the fuel line and yes put that t fitting in between the lineat first thought i was like would that even be safe.
[QUOTE=Tippyman]
thats a good point i wont use it and retard the timing under hood.
ill be buying new clutch and as for dumping the clutch i wouldnt be doing that anyways and i wouldnt spray till 2 3 4 any advice on what i should use to actvite the nitrous in diff rpms?so i dont spray under 3k or to close to reline.
yes i seachred for almost 6 months on thisi just want to clear up on few things.and by looking at your thread who would know better then you?
Old Nov 14, 2006 | 07:35 PM
  #589
Tippyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zccr-xsi &raquo;</TD></TR><TR><TD CLASS="quote">ok i thought u had to cut the fuel line and yes put that t fitting in between the lineat first thought i was like would that even be safe.</TD></TR></TABLE>
I posted pix of how I did it. Just read the directions, it'll tell ya.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zccr-xsi &raquo;</TD></TR><TR><TD CLASS="quote">any advice on what i should use to actvite the nitrous in diff rpms?so i dont spray under 3k or to close to reline.</TD></TR></TABLE>
Use what I am: MSD Window Switch. I got the digital one. It reads what RPM your engine is running at and will only let the nitrous soldenoids ground out when it's within a certain RPM window. Personally, I'm going to set it to turn on at 3000 and turn off at 6500.
The ECU I'm using redlines at 7200 and I'll be stopping right at 6500, so I'll be no-where near redline when under nitrous.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zccr-xsi &raquo;</TD></TR><TR><TD CLASS="quote">and by looking at your thread who would know better then you?
Damn straight!
Old Nov 14, 2006 | 07:41 PM
  #590
zccr-xsi's Avatar
ok ill read about that fuel line setup.ill be useing zex kit so i wont have soldenoids to ground. and i was wondering where abotu u where shuting it off at.
one last thing when i get it all on and get the MSD Window Switch on and ruing by any chance if i do slip and hit wot in first will the nitrous activate?im learning myself how not to hit wot when i launch!
Old Nov 14, 2006 | 07:45 PM
  #591
Tippyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zccr-xsi &raquo;</TD></TR><TR><TD CLASS="quote">one last thing when i get it all on and get the MSD Window Switch on and ruing by any chance if i do slip and hit wot in first will the nitrous activate?im learning myself how not to hit wot when i launch!
If you are within the proper RPM range and you activate the WOT switch, then yes, it will activate. If you really want to prevent yourself from hitting it in first, wire in a push button also.
That way, it will only activate when you're at WOT, within the proper RPM range, AND hit the button. That way you can pick when you wanna spray.
Old Nov 14, 2006 | 07:48 PM
  #592
Got_soy's Avatar
make a trip down to the charleston meet in jan/feb.
Old Nov 14, 2006 | 07:50 PM
  #593
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">
That way, it will only activate when you're at WOT, within the proper RPM range, AND hit the button. That way you can pick when you wanna spray.</TD></TR></TABLE>
i always ran a toggle, WOT switch, and window switch.
launch in first like normal, flip the toggle, go to town!
Old Nov 14, 2006 | 07:51 PM
  #594
zccr-xsi's Avatar
thats sounds what i would like to do but i dont want to to be like in fand f.i honestly dont belive in useing itrous that way.
Old Nov 14, 2006 | 07:52 PM
  #595
Tippyman's Avatar
launch in first like normal, flip the toggle, go to town! </TD></TR></TABLE>
Lol, that's how I'll be doing it. Except I'll have a push button as well.
No traction FTL!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Got_soy &raquo;</TD></TR><TR><TD CLASS="quote">make a trip down to the charleston meet in jan/feb. </TD></TR></TABLE>
Cool. How big is it?
Old Nov 14, 2006 | 07:54 PM
  #596
No traction FTL!
Cool. How big is it?</TD></TR></TABLE>
forgot to add that i flipped the toggle in 2nd.
Old Nov 14, 2006 | 07:55 PM
  #597
zccr-xsi's Avatar
well ill see what happens thanks for the help and advice.
Old Nov 14, 2006 | 07:57 PM
  #598
Tippyman's Avatar
forgot to add that i flipped the toggle in 2nd. </TD></TR></TABLE>
I ain't messin with my toggle, lol. I took my old shift **** (4 speed one) and drilled a hole thru it and ran the push button in that. The wiring has a quick release clip that goes to the main wiring harness hidden in the ash tray.
That way I can plug it in at the track and take it out on the street.
Old Nov 14, 2006 | 07:58 PM
  #599
Tippyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zccr-xsi &raquo;</TD></TR><TR><TD CLASS="quote">well ill see what happens thanks for the help and advice.</TD></TR></TABLE>
No problem man, glad to help.
Old Nov 15, 2006 | 01:32 PM
  #600
Tippyman's Avatar
I re-torqued the head down today to 72 ft lbs.
Some of them were a little loose! They say you should periodically re-torque them down, and I'm glad I did.
