Tippyman's Project Thread
Old Nov 9, 2006 | 05:52 PM
  #526
Tippyman's Avatar
Default Re: (1990si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1990si &raquo;</TD></TR><TR><TD CLASS="quote">thats hard to believe you ran 14.8. not imposssible and i am not saying you arent telling the truth. But damn.</TD></TR></TABLE>
Dude, no one was more suprised than I was. I ran a 14.99 right after that just to prove to myself it wasn't a fluke, lol.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4thgenhtch &raquo;</TD></TR><TR><TD CLASS="quote">Looks Good and quick too </TD></TR></TABLE>
Thanx man.
Old Nov 10, 2006 | 01:12 PM
  #527
Tippyman's Avatar
I'm installing the HG and ARP's tomorrow. Anyone got any suggestions?
Old Nov 10, 2006 | 01:25 PM
  #528
1990si's Avatar
Default Re: (Tippyman)
use the lube they gave you. tighten them in by hand first. torque in the right sequence, and torque slow. you should be good to go. And it will be a bitch getting all that old composite off your block. i suggest a wire wheel on a drill. hopefully you got a mls 3 layer hg aswell.
Old Nov 10, 2006 | 09:05 PM
  #529
Smokinsax's Avatar
The Boot
what shot of nitrous are you going to run?
Old Nov 11, 2006 | 07:11 AM
  #530
Tippyman's Avatar
Default Re: (Smokinsax)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Smokinsax &raquo;</TD></TR><TR><TD CLASS="quote">what shot of nitrous are you going to run?</TD></TR></TABLE>
75 shot.
Old Nov 11, 2006 | 10:54 AM
  #531
EF Sedan Enthusiast's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">I'm installing the HG and ARP's tomorrow.</TD></TR></TABLE>
It's tomorrow, they done yet
Old Nov 11, 2006 | 02:29 PM
  #532
Tippyman's Avatar
Default Re: (jdm_ef3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_ef3 &raquo;</TD></TR><TR><TD CLASS="quote">
It's tomorrow, they done yet </TD></TR></TABLE>
Uploading pix now...
Old Nov 11, 2006 | 02:50 PM
  #533
Tippyman's Avatar
<U>***UPDATE 11/11/06***</U>
Almost finished the ARP and Cometic install. Took about 6 hours to get to where I am now. Ugh...
I began by stripping anything off that would stop the head from lifting off of the block. (Coolant hoses, plugs, distributor, braces, etc.) The timing belt was an absolute *******. I couldn't get the crank pulley off, so I couldn't get the lower timing belt cover off, so I couldn't undo the tensioner, so I couln't get the belt off.
Eventually I had to destroy my lower t-belt cover . I figure what I'll do is get a new one from Honda ASAP and then use my GF's Dad's impact wrench to get the pulley off and re-install it.
Anyway, on to the shitty pix...
When I finally managed to get the head off. (Notice the mangled T-belt cover. )
Look at those rockers! Clean enough to eat off of!
ARP's and Cometic HG just waiting to go on:
ARP's installed:
ARP's and the Cometic HG installed:
As it sits now, the head is sitting on top of the block, not torqued down. I am going to do that tomorrow. That's all for me today...
Old Nov 11, 2006 | 02:56 PM
  #534
yeah tim
Old Nov 11, 2006 | 02:57 PM
  #535
UltimX's Avatar
if u needed help, you should of just asked on how to remove the pully. would of made stuff easier. You also can remove the tensioner out completely or loosen it so the belt will have slack.
Old Nov 11, 2006 | 03:00 PM
  #536
Tippyman's Avatar
Default Re: (UltimX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UltimX &raquo;</TD></TR><TR><TD CLASS="quote">if u needed help, you should of just asked on how to remove the pully. would of made stuff easier. You also can remove the tensioner out completely or loosen it so the belt will have slack.</TD></TR></TABLE>
Well, there was a little hole on the cover where you could get to the tensioner, but it wasn't giving me enough slack, so it needed removing. I know plenty of methods to remove the crank pulley, and spent a good hour and a half trying. It needs a big ******* impact wrench.
Old Nov 11, 2006 | 03:06 PM
  #537
UltimX's Avatar
Theres also a spring on the tensioner you need to remove to give it the most slack.
You don't need an impact wrench. I had one handy and used it but couldn't get it off, both air and electric. I ended up using a 1/2 ratchet with breaker bar and it came loose. The hardest part is keeping the engine from cranking over. Which is easy aswell. just trying to help you out. thats all.
Old Nov 11, 2006 | 03:08 PM
  #538
Tippyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UltimX &raquo;</TD></TR><TR><TD CLASS="quote">Theres also a spring on the tensioner you need to remove to give it the most slack.
You don't need an impact wrench. I had one handy and used it but couldn't get it off, both air and electric. I ended up using a 1/2 ratchet with breaker bar and it came loose. The hardest part is keeping the engine from cranking over. Which is easy aswell. just trying to help you out. thats all.</TD></TR></TABLE>
I had a 1/2'' drive breaker bar, with a 4' cheater bar on it. Jumping up and down didn't break it loose.
Thanx though.
Old Nov 11, 2006 | 03:28 PM
  #539
UltimX's Avatar
was the engine still rotating?
Old Nov 11, 2006 | 03:32 PM
  #540
Tippyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UltimX &raquo;</TD></TR><TR><TD CLASS="quote">was the engine still rotating?</TD></TR></TABLE>
Nope. I fed rope into the cylinder til it couldn't move. Then stuck a screwdriver in the hole in the crank pulley. The bolt was just too strong 4 my weak ***, lol.
Old Nov 11, 2006 | 03:42 PM
  #541
UltimX's Avatar
haha, i never did like that idea. I just put a screw driver in the flywheel side and it hit the block when turned. cranked on the crank pully bolt and it broke loose.
Old Nov 11, 2006 | 03:58 PM
  #542
Autoworks's Avatar
studs and HG lookin good
giterdun
Old Nov 11, 2006 | 04:38 PM
  #543
STREETWERKZ's Avatar
Default Re: (Autoworks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Autoworks &raquo;</TD></TR><TR><TD CLASS="quote">studs and HG lookin good
giterdun</TD></TR></TABLE>
time for the bottle baby!!!!!!
lets see some 13s. one helluva sleeper!
Old Nov 11, 2006 | 04:40 PM
  #544
Autoworks's Avatar
Default Re: (STREETWERKZ)
lets see some 13s. one helluva sleeper! </TD></TR></TABLE>
50 shot FTW
Old Nov 11, 2006 | 06:03 PM
  #545
Ross 2.0's Avatar
In a Junkyard near you.
you punk you should have asked for help! I have a fail proof method to get it off. You need the crank holder tool.
Old Nov 12, 2006 | 04:45 AM
  #546
CRX Toad's Avatar
Pretty soon when you get done you be able to hand a few K's series there behinds.
Old Nov 12, 2006 | 09:00 AM
  #547
swifty4u's Avatar
Default Re: (CRX Toad)
************. you don't know how mad you made me with those times you ran. haha
major props on doing this all yourself! i love these kinds of threads
Old Nov 12, 2006 | 11:29 AM
  #548
50 shot FTW </TD></TR></TABLE>
75 shot. </TD></TR></TABLE>
Old Nov 12, 2006 | 12:00 PM
  #549
1990si's Avatar
Default Re: (swifty4u)
75 shot may be ok, but on a pretty much stock d, it will be pushing that motor to its limits.
Old Nov 12, 2006 | 12:03 PM
  #550
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1990si &raquo;</TD></TR><TR><TD CLASS="quote">75 shot may be ok, but on a pretty much stock d, it will be pushing that motor to its limits.</TD></TR></TABLE>
bullshit.
