Bucking on downshift into vtec
Old 03-14-2015, 02:51 PM
wist00s2k's Avatar
Default Bucking on downshift into vtec
Now that the weather is warm, I've been out doing some spirited driving against other cars. One issue I've ran into is downshifting into 2nd in VTEC is causing the car to buck uncontrollably. Its extremely annoying. Any idea what could be causing it?
The car is a 82mm gsr, high compression, e85 tuned on crome. It made 212whp at 9k for reference.
Old 03-14-2015, 03:09 PM
DO IT ON ALL FOURS
OneBadTurboCRV's Avatar
Default Re: Bucking on downshift into vtec
What is your wideband reading?
Old 03-14-2015, 03:11 PM
93geezr's Avatar
Possibly your TPS? Check to see if it's within range. Also, check your grounds, especially the one on the thermo housing.
Old 03-14-2015, 03:17 PM
ls joker's Avatar
and hows the plugs looking
Old 03-14-2015, 03:46 PM
wist00s2k's Avatar
There is no wideband in the car at this time. I've only had it out a week.
I pulled the plugs and they looked fine.
The grounds seem good, but I'll double check them.
The only time this happens is when downshifting into VTEC. It pulls fine at all other times and never misses.
Old 03-14-2015, 06:06 PM
DO IT ON ALL FOURS
Hopped up engine on CROME and no wideband... riiigghhhttt... Most likely your tune sucks and is too lean when you downshift.
Old 03-14-2015, 09:53 PM
wist00s2k's Avatar
It was tuned on a dyno with a wideband last fall and stored over winter. I just haven't gotten around to buying a wideband for the car.
Didn't know 212whp was "hopped up"..
Old 03-14-2015, 10:21 PM
wunfstgsr's Avatar
When building a high performance engine one of the MOST important things to have is a wide band AFR gauge. 212 whp is a stout B series, i know cause iv had many B series engines. Get a wide band to monitor the afr. You should look into doing some maintenance on the engine since its been stored over winter then retune the engine on the dyno.
Old 03-14-2015, 10:38 PM
wist00s2k's Avatar
Looks like it only happens at part throttle in VTEC. Its fine if I'm wot or on a decel with no throttle input.
Old 03-15-2015, 06:22 AM
DO IT ON ALL FOURS
You have over 1.5x factory whp and don't think it's modified? Interesting concept, but OK; then again you street race soo... Also, just because it was dyno tuned doesn't mean it's good. Most will polish off a street car on the street after the dyno tune and fine tune at the track if it's a track car. What do your datalogs read on what's going on - post some screen shots.
sanman000719
09-05-2012 06:05 PM
es_squared
07-14-2009 07:35 PM
curtisb16
07-26-2007 07:01 AM
fso_BamBam
06-26-2001 04:13 AM
Quick Reply: Bucking on downshift into vtec
