how to check the check engine light
Old 01-09-2007, 08:13 PM
Al-sonic's Avatar
Default how to check the check engine light
something is making my car bog and the check engine light comes on so how do i check it. help
it bogs when i am at normal speed then i have to give it gas to stop the bogs but couple seconds later it bogs again. So i just turn off the car later then it stop but the check engine light comes on
Old 01-09-2007, 08:29 PM
JDM KID 510's Avatar
Default Re: (solbrothers)
If you go to passanger side kick panel and raise up the carpet u sould see your ecu. and above your ECU there will be a lil plug. iIts grey. with 2 wires coming out of it. One wire is black with a white stripe and the other is a red with a black strip.. I take a spare piece of thin speaker wire and cut off both ends so that the actual copper of the wire is showion on both ends. i twist up both ends so that they are in a nice point. stick one end of the wire into the fist socket on the plug. The other end of the wire into the other socket. Turn your key to the ON position.. dont start your car. just to the ON position. Watch your check engine light on your cluster. it will flash.. 1 long flash is 10. the quick flashes are one. so if ur CEL goes !.....!!! that is a code 13. !....!....!!!!! code 25. then take the code #'s and hop on this thread and see what it is. i hope i could help you all.
lgoodgrace
04-27-2015 03:43 PM
Chavy340
10-14-2011 05:17 PM
94whitegsi
08-04-2006 07:22 PM
soon2b
05-22-2005 06:39 AM
95LSDOHC
05-05-2004 09:43 PM
Quick Reply: how to check the check engine light
