AWD EJ2 Build
Old Jun 13, 2011 | 08:43 AM
  #226
purplecivicturbo's Avatar
Default Re: AWD EJ2 Build
What do you mean by ME?
Old Jun 13, 2011 | 09:10 AM
  #227
Jaker's Avatar
I think he's suggesting that since you're a Mechanical Engineer (I don't recall if that's the case), you are doing some pretty advanced EE work.
Old Jun 13, 2011 | 03:21 PM
  #228
Ah i see.. Nah im an avionics or Electronics engineer if you like.. I believe im quite capable of mechanical work but im much stronger with electronics.. And i do like my MOSFETs lol...
Old Jun 13, 2011 | 03:54 PM
  #229
spAdam's Avatar
Loved
Community Favorite
Oh... I thought I remembered you saying earlier in the thread that you were mechanical. Makes sense now, lol
Old Jun 13, 2011 | 05:02 PM
  #230
Blue-Civic-Hybrid's Avatar
Loved
This thread just keeps getting better and better!
Old Jun 14, 2011 | 03:02 AM
  #231
hector44b's Avatar
suscribed, this is definately an interesting thread and cannot wait to see the outcome.
Old Jun 14, 2011 | 03:12 AM
  #232
Glad i could clear it up lol... To be honest im glad i could pull off being a mechanical engineer too lol
Thanks alot chaps.. Trying to save up for this respray is a nightmare, hopefully it wont be too long.. Still got a job list as long as my arm!
Old Jun 16, 2011 | 03:31 AM
  #233
Benj@mmin's Avatar
Wow you're really talented and creative. You Got a lot of cool creative things going on in this build. Keep up the awesome build!
Old Jun 16, 2011 | 05:59 AM
  #234
NA James's Avatar
What is this "vc" that everyone keeps referring to?
Old Jun 16, 2011 | 06:38 AM
  #235
VC? Which page mate..? Im not sure what you mean...
Old Jun 16, 2011 | 10:16 AM
  #236
sanchoem1's Avatar
vc-valve cover
Old Jun 16, 2011 | 10:40 AM
  #237
Thats what i thought mate- but theres also viscous coupler..
Old Jun 18, 2011 | 12:26 AM
  #238
Hey chaps... A little update for tonight..
Managed to spend some time on the new motor controllers, after the last ones broke..
This one is a bit more bulky, and good news, it works perfectly!
Old Jun 18, 2011 | 01:25 AM
  #239
igorka_91's Avatar
Your work is by far the best that i have seen while being a member here on HT for the last few years. Keep it up mate. You got me interested in that S2K cluster. Ill look into it. I have a dc2.
GL
Old Jun 18, 2011 | 06:29 AM
  #240
GL
Thanks mate- thats quite an achievement lol Ill try to keep updates coming- im trying to keep up with demand for the s2000 converters... lol
Old Jun 18, 2011 | 08:20 AM
  #241
NA James's Avatar
I cant find it. Maybe it was the viscous coupler cause there was talk about switching it
Old Jun 18, 2011 | 08:51 AM
  #242
lol fair enough mate- lets go with viscous coupler lol
Old Jun 28, 2011 | 02:47 PM
  #243
a little update for tonight..
Been a bit busy doing some projects for other people here in the UK. I have managed to spend some time on my own again. Decided to do away with my wasted spark system in favour of a coil on plug system...
Ive designed an interface for and Honda ECU (even OEM) which will determine which cylinder is firing and direct the signal to it.. Ive designed mine to run on Audi 1.8T (115-R) coils with integrated ignitors...
The coils are a perfect fit on the engine, the controller board im testing on somebodies car this weekend as mine doesnt run at the moment. But as it stands its all done and dusted.. It can also allow much more retard than standard as well as taking advantage of Hondata S300s latest update which allows adjustable dwell angle (time) to suit the coils, these are 3ms..
Old Jul 1, 2011 | 10:14 PM
  #244
A little update for tonight. Not much been done as ive been a bit busy with some other stuff..
The Audi throttle pedal arrived. Im using this for my drive by wire system.. Long story short, there are 2 pots built into the pedal. At the moment im only using 1, but soon both will be used with error checking between them.
I didnt have the audi connector so i cut back the plastic and soldered my own on. As theyre not covered now, ive just put heat shrink on the spare pins..
Old Jul 3, 2011 | 09:22 AM
  #245
antreasda7's Avatar
wow mate i just read all the thread damn man you have some skills way to go ctrl+D on this
Old Jul 5, 2011 | 02:13 PM
  #246
NA James's Avatar
What drive shaft was used?
Old Jul 6, 2011 | 10:37 PM
  #247
The front drive shafts are B series DSS 5.2's. As the CRV is a B series layout..
The rear drive shafts are custom made (not yet finished) but they will be made my a company here in the UK with CRV inner stubs and Civic outer stubs....
The prop shaft is a CRV one, it needs to be shortened, so when it all goes back together ill know how much to cut it down by and send it to a driveshaft place locally to cut and balance it..
Old Jul 8, 2011 | 11:00 AM
  #248
NA James's Avatar
Ok thanks. Have you seen the new carbon fiber dss driveshaft?
Old Jul 13, 2011 | 03:56 AM
  #249
crikey.. Carbon fibre.. Probably a bit out of my price range!
Hopefully the driveshafts should be okay because the load is distributed between all 4...
Old Jul 13, 2011 | 01:15 PM
  #250
Smokinsax's Avatar
The Boot
has the project been put on hold? what kind of things have you been working on since the last update(s)?
