anyone use a 230v welder on there dryer outlet?
Old 08-23-2004, 11:21 PM
RedTT's Avatar
Default anyone use a 230v welder on there dryer outlet?
I don't know of many people that have done it but most people I talk to say it can be done. Only problem is I'll probably trip the breaker since most dryer outlets are around 30A. Most AC/DC tig welders require 50A. Just wondering if anyone had good experience with this. I would think if the thickest aluminum I weld is 1/8", I would be fine. Anyone with experience?
Old 08-24-2004, 02:21 AM
cirque's Avatar
Default Re: anyone use a 230v welder on there dryer outlet? (RedTT)
I have a Lincoln Square Wave Tig 175 that I ran for a while on a 30 Amp breaker. It took alot to pop it but eventually it would. It seemed like it took less time with aluminum.
Old 08-24-2004, 08:01 AM
RenoRacing's Avatar
Default Re: anyone use a 230v welder on there dryer outlet? (cirque)
I've used my Synchrowave 180 in my dryer outlet and I haven't popped it yet. I've done only a little aluminum about 1/8" thick but a bunch of stainless and mild.
Old 08-24-2004, 12:59 PM
97TegraLS's Avatar
You'll get by for now. Try to get that 50A working.
Old 08-24-2004, 02:59 PM
dustin's Avatar
If you get an inverter welder (like the miller dynasty/maxstar) then the amperage draw is extremely low compared to transformer-based welders.
Old 08-24-2004, 05:52 PM
TeamNextGenChris's Avatar
just helped one of my friends move into a new house.he hasn't built his garage yet,so he's just been running his welder off his dryer outlet.no problems so far(other than the burns in the basement carpet )
Chris
Old 08-24-2004, 09:40 PM
RedTT's Avatar
Thanks guys, going to get me a Syncrowave 180 SD tomorrow
Old 08-25-2004, 08:12 AM
RenoRacing's Avatar
Well, yesterday while welding some thick aluminum with the synchrowave I kept popping the 30 amp dryer breaker. So, after some calling around this morning I found one local place that has a 50amp double pole to replace it. It was a pain in the *** due to the breakers being stab-lok which are apparently pretty fricken old and outdated.
rorik
Welding / Fabrication
26
02-21-2013 02:07 PM
turbojeesx
07-17-2009 05:36 AM
Tjabo
01-26-2009 09:02 AM
Flashmn
17
02-22-2005 11:24 PM
ion_four
11-13-2004 04:03 PM
Quick Reply: anyone use a 230v welder on there dryer outlet?
