TRANSMISSION FLUID POLL!!
Old Oct 12, 2005 | 06:58 PM
  #101
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: TRANSMISSION FLUID POLL!! (9kB20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9kB20 &raquo;</TD></TR><TR><TD CLASS="quote">for now i run MOBIL1 10-30 and it runs fine but ive tried the GM syncromesh/modified and is the **** </TD></TR></TABLE>
Hope that's not synthetic, or you'll soon be sorry.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EnzoSpeed &raquo;</TD></TR><TR><TD CLASS="quote">I was at the dealership today picking up some injector stuff and I asked about what tranny fluid to use. The guy said I'd have no problem running the synthetic. He pretty much talked me out of buying the Honda MTF too. Whatever, I don't really care what I use. I'll blow my tranny in a few more months anyway.</TD></TR></TABLE>
And you're really going to believe what some parts guy told you over what people here with real experiences say? I mean you can go at least 25K miles between trans fluid changes, why not go ahead and get 3 quarts of the good stuff. Honda MTF is only $4-$5 qt. GM Synchromesh is at least $10, expensive yes, but you'll only have to change it like what, once a year if that?
Now I guess if you do actually want to kill the tranny quicker to have an excuse to replace it with something else, use the synthetic motor oil.
Old Oct 12, 2005 | 07:07 PM
  #102
EnzoSpeed's Avatar
Default Re: TRANSMISSION FLUID POLL!! (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">
Well I took your advice and swapped out the synthetic for dino oil. I decided not to listen to the parts guy after he insisted that my trans fluid capacity was 4qts . Man, those guys are dumb.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">I mean you can go at least 25K miles between trans fluid changes, why not go ahead and get 3 quarts of the good stuff. Honda MTF is only $4-$5 qt. GM Synchromesh is at least $10, expensive yes, but you'll only have to change it like what, once a year if that?
Now I guess if you do actually want to kill the tranny quicker to have an excuse to replace it with something else, use the synthetic motor oil.</TD></TR></TABLE>
Well my car is a full race car, so I only drive it about 8k miles per year. But I guess it comes down to me not really caring. Even if the Honda MTF was free, I wouldn't drive to the dealership to buy it when I can just drive down the street to Autozone and buy whatever. Seriously, I don't think it really matters what trans fluid you use. But then again, a new tranny for my y8 is only $100, so maybe you guys with type-R's and whatnot are more ****.
Old Oct 12, 2005 | 07:12 PM
  #103
Community Builder
Well yeah my car being my only mode of transportation, I can't be having the synchros go out on me.
But I would still probably run some good stuff in a race car, at least if there was alot of money in it.
Old Oct 12, 2005 | 08:31 PM
  #104
EnzoSpeed's Avatar
Default Re: (PatrickGSR94)
I put $10,000 in my motor/turbo setup and $0 into my tranny . Maybe I'll run some good stuff when I get a quaife.
Old Oct 13, 2005 | 08:58 PM
  #105
raffiT78's Avatar
Default Re: TRANSMISSION FLUID POLL!! (MtnCRX)
i use regular 5 w 30
Old Oct 14, 2005 | 06:13 AM
  #106
Community Builder
Default Re: TRANSMISSION FLUID POLL!! (raffiT78)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raffiT78 &raquo;</TD></TR><TR><TD CLASS="quote">i use regular 5 w 30 </TD></TR></TABLE>
in your transmission? ughh that's too thin... .at least use the correct viscosity even if you don't use transmission fluid.
Old Oct 14, 2005 | 08:53 AM
  #107
LSVTEC 91 Civic's Avatar
Banned
Just filled my replacement LS tranny with some Pennzoil Synchromesh.. shifts so much smoother.
Old Oct 19, 2005 | 04:49 AM
  #108
Finland's Avatar
Default Re: TRANSMISSION FLUID POLL!! (LSVT3K 91 C1V1C)
with my first transmission, I used MTF, 10w30, and syn 10w30. After going to the strip, I noticed "notchyness" after using both the 10w30 and MTF. I would change the MTF after every drag session. Ultimately my shifting errors caused the demise of my 3rd and 5th synchros.
This spring I installed a new transmission from Acura. I broke it in for about 500 miles with MTF, then changed the MTF, drove it around for another couple of hundred miles, then I put in Pennzoil Synchromesh and noticed an improvement in shift feel. The impact seemed to improve over several weeks, as if it had to impregnate all the components.
I'll analyze the fluid when I change it next. So far I have about 2K on the Pennzoil Synchromesh and am satisfied with it.
Old Oct 19, 2005 | 04:30 PM
  #109
EnzoSpeed's Avatar
Default Re: TRANSMISSION FLUID POLL!! (Boondock Saint)
Damn, my new tranny is already grinding and it's only been two weeks .
Maybe I'll give in and try the syncromesh. Or maybe my tranny just doesn't like to shift over 8,000.
Old Sep 2, 2010 | 05:51 PM
  #110
cody2689's Avatar
Default Re: (thatbluecrx)
Originally Posted by Jason.H.
yea i use the new royal purple syncro max. its good ****. befor that i used penzoil syncromesh it was excelent as well, formulated to match GM syncromest but its only 4$ a quart.
I actually sent an email to royal purple and they told me they do not recommend using there syncromax. They said I would be better off just using there 10w30 motor oil
Old Apr 4, 2012 | 06:31 PM
  #111
Mongo CRX's Avatar
Honda recommends engine oil in my 88 CRX tranny
I used Mobil 1 for 100K+ miles
Switched to Amsoil MTF about a year ago, IT IS WAY BETTER
http://www.amsoil.com/storefront/mtf.aspx
Twentys95hb
Transmission & Drivetrain
Jun 25, 2009 09:34 AM
dohcgarage@714
Honda S2000
11
Sep 12, 2008 01:39 PM
tthomass
Jan 12, 2006 07:43 PM
wicx
Oct 25, 2002 10:07 AM
junglistgsr
Sep 21, 2001 12:21 AM
