serious problem help me please
Old Jan 23, 2003 | 08:16 PM
extrmeboost's Avatar
Default serious problem help me please
the other day i replaced my t3/t4 with a t3 just for kicks, when i put the t3 on it ran ok for a few minutes then i smelled oil, i pulled over to discover the turbo not spinning at idle and lots of oil and smoke on the exhaust side of the turbo. i figured the turbo was bad so i bought another t3( i got em both cheap)
well this turbo is doing the same thing, except i noticed coolant trickling down the block. i took the turbo off the manifold and ran the car for a sec to see if the oil was coming before the turbo, it looked like it was coming from the head, but im not sure, any ideas on what the hell is wrong, i hope its just a head gasket
Old Jan 23, 2003 | 08:39 PM
Shawn C's Avatar
In The Garage
Default Re: serious problem help me please (extrmeboost)
man i think you need to use teflon tape on the oil/coolant fittings on the turbo. sounds like theyre leaking.
edit- how much can you get those t3s for?
[Modified by 22lbGS-R, 11:42 PM 1/23/2003]
Old Jan 23, 2003 | 08:43 PM
Default Re: serious problem help me please (22lbGS-R)
i did use teflon tape, the point was i think there is oil and coolant leaking somewhere other than the turbo, but the turbo's compressor wheel is not spinning at idle???
Old Jan 23, 2003 | 08:52 PM
Shawn C's Avatar
In The Garage
.....the turbo's compressor wheel is not spinning at idle???
it wont on a small engine. it starts to spool at like 2500 RPM
Old Jan 23, 2003 | 09:09 PM
i got one for $50 and the other i traded a playstation for
but shouldnt the wheel be spinning a little at idle??
Old Jan 23, 2003 | 09:13 PM
Kamin's Avatar
how the **** did you get a turbo for 50$
im sorry but if i bought a 50$ turbo i wouldnt expect it to work.
put the 3/4 back on and see if it works.
Old Jan 23, 2003 | 09:40 PM
Default Re: serious problem help me please (Kamin)
youd be surprised, i can get good turbos for pretty cheap, hell my friend just bought a freshly rebuilt t72 for about $500 but thats not the point, the same thing has happened with two different turbo chargers, and the whole oil and coolant thing has thrown me off, i assume its a head gasket, i stupidly replaced the head gasket with composite one.
Old Jan 23, 2003 | 09:41 PM
TEAMGENDAI's Avatar
is you return line kinked or too long or to thin??? also you should have only a -3 to feed it and a -12 to drain!! just my opinion. also prime the turbo before you install it just add a little oil to the turbo feed or drain hole. as far as the coolant goes dont have clue sorry. i would have be standing in front of the car.
Old Jan 23, 2003 | 10:00 PM
Default Re: serious problem help me please (TEAMGENDAI)
so your saying the return line being kinked would cause this problem? whats your input on the turbo spinning at idle?
Old Jan 23, 2003 | 10:02 PM
TEAMGENDAI's Avatar
bad bushing's or really low idle just a thought i could be wrong... oh you saw the turbo not spinning after your first pass?? that would not primng the turbo theroy. but one more question how much boost are you running?
[Modified by TEAMGENDAI, 7:04 AM 1/24/2003]
Old Jan 23, 2003 | 10:13 PM
10K2HVN's Avatar
can i get one??? ..just to put in my room..imma NA kinda guy...
Old Jan 24, 2003 | 07:33 AM
madman13lm's Avatar
Default Re: serious problem help me please (10K2HVN)
My grandfather was FI, he was on a breathing machine for a number of years
Old Jan 24, 2003 | 08:56 AM
LS-hatch's Avatar
Default Re: serious problem help me please (madman13lm)
haha at what rpm did he reach full boost? I bet he was running Nos sometimes.
Old Jan 24, 2003 | 08:57 AM
LS-hatch's Avatar
Oh yeah if its trickling down the block id say its a headgasket. But id try putting the t3/t4 back on first.
smoovy
Apr 19, 2009 11:09 AM
b20beast83
Apr 3, 2009 12:35 PM
B18badboy
May 10, 2004 01:50 PM
BoOsTiN Dc2
Mar 29, 2004 09:23 AM
MisterB
Nov 7, 2001 05:13 PM
