Bad Turbo or Do i need Restrictor?
Old Apr 2, 2009 | 06:42 PM
b20beast83's Avatar
Default Bad Turbo or Do i need Restrictor?
Heres the Deal.
I got a turbo Si T3 T4 Turbo
1/2" Oil Return
When car Starts, there is no oil smoke.
It Gradually starts to smoke
After a while at idle, there is thick oil smoke.
Driving, there is clouds of smoke
My Return line has no kinks or does not hang upwards.
I even Drained out some oil in the pan to see if the return was blocked.
PLEASE give me some valuable input
Old Apr 2, 2009 | 08:30 PM
TurbodTegSfaria's Avatar
Default Re: Bad Turbo or Do i need Restrictor?
used to have the same problem with my ebay turbo..worked great too much oil was burning..ran restricter with a little somthing and car ran fine after that...car still ran 118mph at 10 psi with that turbo.....
kiss
Old Apr 2, 2009 | 08:45 PM
superslinky's Avatar
man i had the same problem, and i know this wont help you but i just switched the turbo and thought my friend i bought it from screwed me.
Old Apr 2, 2009 | 11:00 PM
boostatic's Avatar
if you think ur turbo is smoking then just take off the downpipe from the turbo..if the seals are blow then you'll most likely see oil coming out of the exhaust housing..
Old Apr 3, 2009 | 04:27 AM
b20beast83's Avatar
its a garrett t3 t4
oh i bought the turbo used and changed bearings and seals.
and smoke is from the turbo
Old Apr 3, 2009 | 06:22 AM
all4bspinnin's Avatar
what size oil feed line are you using?
Does this turbo smoke all the time when driving or only at idle?
Old Apr 3, 2009 | 09:23 AM
b20beast83's Avatar
smokes all the time
-3an feed
Old Apr 3, 2009 | 12:35 PM
typically if the turbo is smoking all the time and you are using the correct feed, the oil line is not kinked...
Sounds like the turbo is going out.
Call mike @ evergreen turbo and tell him dave from Jacksonville sent you
He has over 20 years of turbo building experience and knows turbo's better than anyone i have ever talked to. His rebuild prices are really cheap too!!!
http://www.evergreenturbo.com/
1800-275-2531
and the best part, he's in ocala FL
b20beast83
Apr 2, 2009 07:36 PM
rideblitz
Nov 16, 2004 03:55 AM
01ITR#700
Aug 7, 2003 06:25 AM
Ntrpriz
Jun 29, 2003 08:10 PM
