OBD2 --> OBD1 conversion question
Old Apr 26, 2007 | 07:11 PM
JokerX-1.6T's Avatar
Default OBD2 --> OBD1 conversion question
I was just wondering what else is needed for the conversion to obd1 ? I have a
2000 civic coupe D16y8 Im converting to obd1 with a chipped p28 with crome and obd2 to 1 conversion harness and have done the 3 wire to 2 wire iacv fix since also going from auto to manual with a manual intake manfiold and throttle body. Is there anything engine wise that needs also to be changed ? I know I lose the knock sensor and 2nd O2 sensor, what about the distributor does that needs changing also?
Any input would be appreciated
Old Apr 26, 2007 | 08:59 PM
Bueller
Old Apr 27, 2007 | 07:05 PM
boostedblkef's Avatar
Default Re: (JokerX-1.6T)
you can still use your obd2 dizzy the only real difference is the plug
Old Apr 28, 2007 | 04:48 AM
Blown90hatcH's Avatar
Default Re: (boostedblkef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedblkef &raquo;</TD></TR><TR><TD CLASS="quote">you can still use your obd2 dizzy the only real difference is the plug </TD></TR></TABLE>
What he said. Everything else is fine.
Old Apr 28, 2007 | 01:59 PM
whats needs to be done to the plug ?
Old Apr 28, 2007 | 02:43 PM
slvrcvc93's Avatar
dont do anything to the plug as long as it clips in your fine if you are using obd 1 engine harness 2 main power wires from the dizzy are on the clip on a obd 1 motor the dizzy has 2 seperate clips thats the diffrence
Old Apr 29, 2007 | 01:41 PM
this is just a obd1 ecu and ecu conversion harness on a 2000 y8 motor obd2b
Old Apr 29, 2007 | 02:04 PM
your fine man just use the obd1 ecu and the conversion harness thats it
JokerX-1.6T
Apr 26, 2007 09:16 PM
BLUE EH3
May 13, 2005 08:19 PM
HamiltonRex
Mar 22, 2005 07:53 AM
CRXLST
Sep 20, 2004 10:34 AM
5 Skware
Jul 30, 2003 04:32 AM
