OBD2 --> OBD1 conversion question
I was just wondering what else is needed for the conversion to obd1 ? I have a
2000 civic coupe D16y8 Im converting to obd1 with a chipped p28 with crome and obd2 to 1 conversion harness and have done the 3 wire to 2 wire iacv fix since also going from auto to manual with a manual intake manfiold and throttle body. Is there anything engine wise that needs also to be changed ? I know I lose the knock sensor and 2nd O2 sensor, what about the distributor does that needs changing also?
Any input would be appreciated
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedblkef »</TD></TR><TR><TD CLASS="quote">you can still use your obd2 dizzy the only real difference is the plug </TD></TR></TABLE>
What he said. Everything else is fine.
dont do anything to the plug as long as it clips in your fine if you are using obd 1 engine harness 2 main power wires from the dizzy are on the clip on a obd 1 motor the dizzy has 2 seperate clips thats the diffrence
JokerX-1.6T
Apr 26, 2007 09:16 PM
HamiltonRex
Mar 22, 2005 07:53 AM
5 Skware
Jul 30, 2003 04:32 AM
