turbo problems
Old Apr 7, 2005 | 08:35 PM
drift4food's Avatar
Default turbo problems
Well i just installed a turbo kit on my car after is blew up the first time. I got a new rebuilt motor now. Well at first i started the car is smoked a little bit. then i drove down the road and it started to smoke more. Now is smokes all the time. Like a blown head gasket. But how i dont know why. I have a thick metal head gasket on there. And only boosting 5 psi. If anyone can help me out that would be awsome. Thanks
Old Apr 7, 2005 | 08:41 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: turbo problems (drift4food)
double check your return line... sound like the seals in the turbo are blown
who made the turbo?
kinda ot... but my friends lives in cary, lol. that was random.. i know
Old Apr 7, 2005 | 08:43 PM
Evo-man@20psi's Avatar
I take it its smoking from the exhaust ??
Old Apr 8, 2005 | 08:33 AM
beepy's Avatar
Default Re: turbo problems (WAsianMotorSports)
Your oil feed/return isn't right. You have probably already blown your new turbo seals. Give us a picture/description of the oil feed and oil drain. If this is a turbo kit, the lines you got should be good, assuming you installed them right. My guess is that where you drain into the oil pan is too low. I see it all the time.
Old Apr 8, 2005 | 10:14 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: turbo problems (beepy)
yea... its your turbo, no coolant here.....
Old Apr 8, 2005 | 10:17 AM
B18C1CYA's Avatar
well lets see the return line , and also how did it blow up the first time ??? cus if it had broken ring lands and was burning oil that takes some time to burn out of the exhaust system ,
Old Apr 8, 2005 | 10:27 AM
EJ1 wilcox's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WAsianMotorSports &raquo;</TD></TR><TR><TD CLASS="quote">well the turbo isnt water cooled. And last night i took the head off and the head gasket is good. And no cracks in the cylinder walls. Its a turbonitics turbo. I am totally stumped. Would blown rings cause it to blow coolent?</TD></TR></TABLE>
Damn dude, you pulled the head without checking your oil feed/return first?
Sounds like your turbo seals are having problems... let's see some pics of your setup, maybe it's something obvious...
Old Apr 8, 2005 | 11:03 AM
drift4food's Avatar
Default Re: turbo problems (EJ1 wilcox)
When the motor first blew to overboost the number 2 cylinder wall broke a chunk off. So we got a new bottom end. And got the head done. And its not oil burning its coolent its white with a sweet smell. The only thing i have noticed on the head is when it blew the first time some of the spark plugs shattered and left some small cuts on the out side of the valve valley. Also the oil return line is at a high point on the oil pan. It might be something really stupid but i am confused.
Old Apr 8, 2005 | 04:03 PM
non-VTEC's Avatar
did you have the deck of the block re-surfaced as well as the head?
sounds like a bad headgasket if its blowing white smoke........
Old Apr 8, 2005 | 05:07 PM
Evanmb44's Avatar
Default Re: turbo problems (non-VTEC)
if you didnt have the head resurfaced that could be your problem. make sure it is tight down too
93 Eg Couper
May 2, 2011 02:21 PM
boostedcoupe1
Feb 20, 2008 01:55 PM
hold your breath
Feb 14, 2007 10:01 AM
onelowchef
May 7, 2006 09:11 AM
kj98r
May 16, 2004 03:16 PM
