I can' adjust my timming
Old Oct 1, 2001 | 03:45 PM
allmotorEG-SI's Avatar
Default I can' adjust my timming
oops, I posted something saying I couldn't adjust my idle, my timming was what I'm talking about. I'm tried give me a break ok BUt my distrib. bolts are stripped around the edges and thus I can't move the distrib to adjust. DOes anyone know of another way to adjust the timming without the turing the distrib.
Old Oct 2, 2001 | 08:42 AM
H23 Power's Avatar
Default Re: I can' adjust my timming (CAMAROCRUSHER)
other than re-mapping the ecu, i dont think there is another way
Old Oct 2, 2001 | 10:09 AM
Spade's Avatar
Default Re: I can' adjust my timming (01GSR)
Try vice grips to remove the bolts and get a new set to replace them also put some anit-seeze on them before you stick them back in.
Old Oct 2, 2001 | 12:11 PM
the vice grips didn't help either. They stripped the bolt as bad as the wrench could have. IT also has a hole for a philips screw drive. I would use an impact driver but the distrib has somemetal in the way blocking me to put any type of screw driver in there. at this point I might as well just bust out the die-grinder or something and hack that little S.O.B off. than maybe i'll be able to advance my timming tp the correct deggree
Old Oct 2, 2001 | 12:38 PM
Spade's Avatar
Sure, that would work but then you gotta get the posts out. Is there a way to get a drill in there to drill the center and then un....no the metal is in the way huh? Drill a hole in the metal to make a strait through shot at the screw or remove the metal if you can.
Old Oct 2, 2001 | 02:45 PM
JunkeeCrx's Avatar
New User
Default Re: I can' adjust my timming (Spade)
I had the same problem with the bolts, and vice grips worked for me. You just gotta clamp down on that thing really really hard. also try filing down a flat spot before using the vice grips!
...thats my 2 cents
Old Oct 2, 2001 | 04:39 PM
Default Re: I can' adjust my timming (JunkeeCrx)
...thats my 2 cents
I had someone a whole lot stonger than me tighten down the vice grips and the metal just seemd soft and brittle as the vice grips turned. but fileing down some flat sides on it sounds good.
Old Oct 3, 2001 | 11:14 AM
JunkeeCrx's Avatar
New User
just a side note, make sure the engine is cold when using those vice grips. once the engine heats up, those bolts get really hot, and soft. plus, if yours are like mine, they are a goldish/brass color. I personally think the metal used to make those bolts is really to soft. that is the main reason they strip, the heat, and they're cheap. so try it in the morning or something before you drive anywhere. that worked for me.
ameer_vtec99
Mar 28, 2013 01:46 AM
97civic123
Jan 18, 2008 08:48 PM
aaj23
Jan 31, 2005 10:45 PM
Sassafrass
Apr 24, 2003 11:40 AM
syndicate43
Nov 25, 2002 05:49 PM
