how to pull codes??
Old Jan 8, 2002 | 01:37 PM
sydag5's Avatar
Default how to pull codes??
How do you I pull check engine codes for a 98 civic?
Old Jan 8, 2002 | 01:45 PM
Doctor CorteZ's Avatar
Default Re: how to pull codes?? (sydag5)
two pin connector in a green rubber dummy plug under right dash,jump the two wires,turn the key on and count the flashes
salbaje's Avatar
on the right side kick panel there are 2 plugs one with 2 wires and other with 3 jump the one with two wires and turn your ignition to on position not start and count how many blinks your check engine light goes. one long blink is 10 and short blinks is one. and long pause in between for another code
Old Jan 8, 2002 | 02:39 PM
smp534's Avatar
New User
Default Re: how to pull codes?? (salbaje)
how bout for OBD1 cars?
95 civic
Old Jan 8, 2002 | 05:03 PM
BreakStuff's Avatar
New User
Default Re: how to pull codes?? (smp534)
95 should be the same method and have that same 2 pin connector.. like they used to say "Were way Ahead of Our Time"... Many 1995 OBDI cars share the same troubleshooting procedures as their 1996 counterparts...
TegraD
Aug 16, 2008 07:05 PM
Bambinoh
Apr 25, 2007 04:35 AM
SR20 Inside
Feb 3, 2006 06:42 PM
allmotorEG-SI
Jul 20, 2004 09:51 PM
CivicEx95
Apr 28, 2002 09:34 PM
