What could cause the...
TPS to keep going out? ive replaced it 3 times already but some how it keeps messing up. Is there anything that could cause it to keep messing up?
Re: What could cause the...
or everytime you throw a tps code you simply replace the tps instead of diagnosing it... sounds like your blindly slapping a new tps each time it sets a code, you do know when installing a tps sensor, it requires calibration and if not calibrated, it will set a code again
what they said, the problem may not even be the TPS itself!
and yeah u need to calibrate the TPS to .5 volts when throttle is fully closed and 4.5 volts on wide open throttle.
