d15b vtec ?s
im thinking about putting a d15b in my car and i wanted to know more about it, is the block just like other usdm d15b? Such as oil pressure, bore X stroke, etc etc
thanks for any replies
yes, they are the same - be careful when getting D15B - there are 3 versions - the normal VTEC, a 3 stage VTEC and an economy version which is only about 90hp
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx »</TD></TR><TR><TD CLASS="quote">yes, they are the same</TD></TR></TABLE>
so would i get same results from complete d15 vtec and usdm d15b2 block with d15 vtec head?
Lest compression would be the NON VTEC heads.
The JDM D15B SOHC VTEC has stonger and longer rods than a standard USDM D15
same length as D16 rods, BUT THE D16 and D15 RODS DO NOT INTERCHANGE!!!
Think of the D15B SOHC VTEC as a USDM D15 prepped for higher revs.
does anybody know the name of this kinda vtec...it activates by oil pressure ( read from some web ) so would d15b2 block be better with that vtec since its got 24 extra psi for oil pressure???
