d15b vtec ?s
Old Sep 25, 2003 | 06:10 PM
youngwon22's Avatar
Default d15b vtec ?s
im thinking about putting a d15b in my car and i wanted to know more about it, is the block just like other usdm d15b? Such as oil pressure, bore X stroke, etc etc
thanks for any replies
Old Sep 25, 2003 | 07:14 PM
jlicrx's Avatar
Default Re: d15b vtec ?s (youngwon22)
yes, they are the same - be careful when getting D15B - there are 3 versions - the normal VTEC, a 3 stage VTEC and an economy version which is only about 90hp
Old Sep 25, 2003 | 08:18 PM
youngwon22's Avatar
how could i tell the difference?
Old Sep 26, 2003 | 06:41 AM
jlicrx's Avatar
Default Re: (youngwon22)
the 3-stage VTEC has 2 VTEC solenoids, doesn't say VTEC on valve cover - the VTEC-E (economy) has smaller intake, doesn't say VTEC on the valve cover
Old Sep 27, 2003 | 02:06 PM
my_slow_civic's Avatar
Default Re: (jlicrx)
Does it have to have vtec on the valve cover?
Old Sep 29, 2003 | 03:28 PM
youngwon22's Avatar
Default Re: d15b vtec ?s (jlicrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx &raquo;</TD></TR><TR><TD CLASS="quote">yes, they are the same</TD></TR></TABLE>
so would i get same results from complete d15 vtec and usdm d15b2 block with d15 vtec head?
Old Sep 29, 2003 | 04:09 PM
Sinner's Avatar
I have a boosted d15b jdm vtec. They are alot of fun. you never gonna get power out of them like say a b motor. but if your goal is 200hp then it will be fine.
Old Sep 30, 2003 | 07:58 AM
EG-lowrider's Avatar
what head does anyone think would yeild the LEAST compression on a d15b7? wheres mista bone when i need him
Old Sep 30, 2003 | 09:07 AM
HumanResource's Avatar
Default Re: (almost boostin)
Lest compression would be the NON VTEC heads.
The JDM D15B SOHC VTEC has stonger and longer rods than a standard USDM D15
same length as D16 rods, BUT THE D16 and D15 RODS DO NOT INTERCHANGE!!!
Think of the D15B SOHC VTEC as a USDM D15 prepped for higher revs.
Old Oct 5, 2003 | 09:20 PM
youngwon22's Avatar
does anybody know the name of this kinda vtec...it activates by oil pressure ( read from some web ) so would d15b2 block be better with that vtec since its got 24 extra psi for oil pressure???
Old Oct 5, 2003 | 09:54 PM
R@mon's Avatar
i dont see why your worried about the difference in oil pressure. All vtec motors engage the bigger lobes using oil pressure. (B,D,H,F,K series)
Scoberdoo
Sep 5, 2018 08:31 AM
FirstCRX
Sep 22, 2014 12:09 AM
Stevemyster
May 16, 2011 12:45 PM
Didly
20
Nov 23, 2005 07:49 PM
bad93ex
Jul 26, 2002 11:37 PM
