Code 22
Old Jan 30, 2002 | 11:20 AM
pelotudo's Avatar
Default Code 22
I hooked up my LED to my VTEC enguagement wire coming out of the VTEC selenoid last night. It lights up now when VTEC kicks in....woohoo.. Only downfall...I am now getting Code 22 from my ECU. I know this is the VTEC Pressure switch code, but is it hurting anything? The wire tapped (gator clipped) to the green/white wire coming from the selenoid is causing the problem. If I take it off, will it go away, or once the wire is violated....it has to be replaced? If I leave the wire on and reset the ECU, will it have any bad affects?
JB
Old Jan 30, 2002 | 11:43 AM
sgT's Avatar
sgT
Default Re: Code 22 (PeloTudo)
the pressure switch is the green plug on the side of the solenoid.
check your connections. or it may just be bad
Bump
Sep 28, 2005 04:12 PM
pbizzlegsr
Oct 15, 2004 01:10 PM
lonefuzzy79
Apr 18, 2003 06:52 AM
pelotudo
Jan 30, 2002 03:02 PM
prjctCIVIC
Jul 7, 2001 09:50 PM
