Homemade ITBs
Old Jan 22, 2002 | 10:43 PM
martini's Avatar
Default Homemade ITBs
I don't know how many of you people are DIY type guys...but I sure am. There are so many things that you can do by yourself, and save a lot of money, and have more fun doing it...you just have to have the mind set. I fabricated a dash for my racecar, a switch panel (with fuses and indicator lights), an intake (with heatshield), door skins, headlight brackets, Mounting bars for the FG front end, and I plan on fabricating my own exhaust, I even made my own valve spring compressor.. I love doing this stuff, it's so satisfying when you're finished.
So I'm now scheming up a plan to fabricate my own Individual Throttle Bodies.
I'm looking at hacking up a regular old B series intake manifold, porting it out, welding on 4 Geo Metro throttle bodies to the runners (or something of comparable size, 50mm or less. I know some Saturns have 50mm TBs), and then, of course, the air horns on the end. Plus some sort of filter, probably just an open element foam type filter. It all seems too easy.
Anyone out there with ITBs care to share some opinion on my idea?
Now, I've been studying a little on fluid dynamics and I know that a lot of the low end grunt would be lost with a setup like this (but with big gains in the high end). This is acceptable to me. But if I really want to get technical about it, I was thinking of making a variable intake runner (a longer, skinnier runner going to the airbox surrounding the air horns kept open for the low rpms, and then for the high rpms, an open element type system. This would get the best of both worlds. Of course, that's a lot of engineering to do, but I'm up for a challenge.
I'd probably end up cutting up my fiberglass front end to mount some sort of hood scoop to bring in a breath of fresh air for the things as well.
[Modified by martini, 7:49 AM 1/23/2002]
Old Jan 23, 2002 | 08:55 PM
martini's Avatar
Default Re: Homemade ITBs (martini)
I guess no one has any comments..
I'll try in the competition forum.
Old Jan 23, 2002 | 08:58 PM
Gasoline Fumes's Avatar
Those Metro TBs are about 35mm. Perfect.
Old Jan 23, 2002 | 09:06 PM
Mike95lude's Avatar
I think that's sweet. Go for it
Old Jan 23, 2002 | 09:51 PM
peebrain's Avatar
Default Re: Homemade ITBs (Mike95lude)
if it works ill buy one!
what head are you using?
patent a kit...and make a killing, even if it makes twice as much as a cold air intake, you can still sell it, by the sounds of it smaller t.bs would be good for the street, and still be able to make good top end power
Old Jan 24, 2002 | 07:04 AM
martini's Avatar
Default Re: Homemade ITBs (NatuRaldisasteR)
Well, I have a B16A head on my LS/VTEC, and my bro has a B16A in his del sol.
I hadn't thought about selling it. But that would be a good idea, and great to increase traffic to our website (when it gets up)..
Old Jan 24, 2002 | 07:50 AM
peebrain's Avatar
exactly
Old Jan 24, 2002 | 08:42 AM
92sleepR's Avatar
New User
Sounds completely possible. You will have to make sure that all the TB's are properly linked so that all the throttle plates open the same amount at exactly the same time. I would also keep the existing runners on the manifold slightly on the long side to help low end torque. If you ar good with a welder the fabrication should be pretty straight forward.
Couple that setup to a nice cold air intake and high comp pistons and you will have yourself quite an engine.
Mike
Old Jan 24, 2002 | 10:09 AM
HaUTSaauce's Avatar
New User
i would like to see some pics martini
Old Jan 24, 2002 | 11:07 AM
sgT's Avatar
sgT
Default Re: Homemade ITBs (Gasoline Fumes)
35mm is way to small
Old Jan 24, 2002 | 12:47 PM
martini's Avatar
Default Re: Homemade ITBs (sgT)
I think so too. the ones they use on the TWMinduction ITBs are 50mm...That's inner diameter of course. The Metro ITBs probably have a little bit more padding on the outside.
Old Jan 24, 2002 | 03:57 PM
vpc's Avatar
vpc
New User
Homemade intake manifolds aren't the brightest idea in the world. This one I made caused me to blow my motor.
Old Jan 24, 2002 | 04:11 PM
976's Avatar
976
New User
Default Re: Homemade ITBs (vpc)
I just s**t my pants laughing so hard...
Good one bro!
Old Jan 24, 2002 | 04:27 PM
Mattydevine's Avatar
Damn, man i want to buy that brown intake mani, thats a sweet job. Keep up the good work, i'll be watching for a header in the near future...
Old Jan 24, 2002 | 04:53 PM
Katman's Avatar
hehe...
Old Jan 24, 2002 | 04:54 PM
bryant's Avatar
Default Re: Homemade ITBs (Katman)
Now thats nice!
[Modified by CR-X, 7:55 PM 1/24/2002]
Old Jan 24, 2002 | 04:57 PM
neof69's Avatar
DUDE!!!!!! That is fawkin sick!!!!! LMAO!!!..............That is the craziest shheiit i have ever seen..........LOL......
Old Jan 24, 2002 | 05:08 PM
Katman's Avatar
Default Re: Homemade ITBs (neof69)
hey....who's the pissed off lil kid in the window?
Old Jan 24, 2002 | 08:50 PM
Chugger's Avatar
thats not a bad idea i would have to get it welded by someone else because id tear something all to hell if i was able to melt metal the itbs off the metro is that a geo metro or what and how would i fabricate a throttle cable braket so it pulls all four i think 35mm would be plenty for a dseries motor wouldnt it? let me know help me something its an idea i wanta use
thanks
chris
Old Jan 24, 2002 | 11:58 PM
vpc's Avatar
vpc
New User
Oh you guys think thats funny? How about a lsd. 2 way sucka!
btw I do have a life and No these 2 things did not take a long time. Okay maybe the lsd...but the manifold took like 20min.
Old Jan 25, 2002 | 12:02 AM
HaUTSaauce's Avatar
New User
hahahahhahahhaha thats funny as hell
Old Jan 25, 2002 | 03:03 AM
JKim0901's Avatar
Default Re: Homemade ITBs (HaUTSaauce)
man you must have alot of time on your hands....
Old Jan 25, 2002 | 08:58 AM
vpc's Avatar
vpc
New User
Default Re: Homemade ITBs (JDM EG HATCH)
look at the disclaimer underneath the lsd pic foo.
Old Jan 25, 2002 | 11:01 AM
GEN2 HYBRID's Avatar
Creative and funny.....
Totally brightened my day, thanks.
Old Jan 25, 2002 | 11:06 AM
Kataku2K3's Avatar
Default Re: Homemade ITBs (GEN2 HYBRID)
Do you make a custom cardboard turbo kit or a clutch? I like the brown poo poo......hehe!
[Modified by JDMspecEG6, 6:46 PM 1/27/2002]
