Help code 17 VSS signal( i did a search)
i need your help guys
im getting code 17 which is VSS
i replace both the VSS sensor with a new one and i also got a new cluster and my speedometer still doesn't work and i still go in to limp mode
Re: Help code 17 VSS signal( i did a search) (u2civic1)
IS YOUR SENSOR, RIGHT BELOW THE THROTTLE BODY ON THE TRANNY, CHECK TO SEE IF IS HOOKED UP, IF IT IS, REPLACE THE SENSOR, I HAVE ALOT OF THEM FOR SALE... CHECK IT OUT...
Re: Help code 17 VSS signal( i did a search) (1320DRAGWORKX)
a couple of things for ya...
1) check the ground on your Thermostat Housing
2) unplug you VSS and look at the pins on the inside of the harness side plug
3) take the cluster back b/c that's not your problem
4) tell me what year, make and model your car is
Re: Help code 17 VSS signal( i did a search) (DSeriesBKilla)
its ******* bullshit, my VSS is broken, buy another functioning one (the owner was USING it right before me) and it doesn't work. then i try my boy dave's VSS and it doesn't work, when we go to put it back in his car, HIS doesn't work. after ******* around all this time, i drive home and it starts working for me, but only for about 10 minutes before the code starts pulling up again and i can't see my mph.
now i gotta pay for 2 VSS's and make sure both run right
Re: Help code 17 VSS signal( i did a search) (thenick)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thenick »</TD></TR><TR><TD CLASS="quote">its ******* bullshit, my VSS is broken, buy another functioning one (the owner was USING it right before me) and it doesn't work. then i try my boy dave's VSS and it doesn't work, when we go to put it back in his car, HIS doesn't work. after ******* around all this time, i drive home and it starts working for me, but only for about 10 minutes before the code starts pulling up again and i can't see my mph.
now i gotta pay for 2 VSS's and make sure both run right </TD></TR></TABLE>
Mine does this as well. I only get the code every once and a while and my speedo will work probably 2-3 times a day when I'm driving. It all started happening after I got my clutch done. Never tried to put a new VSS in though so iono.
Re: (thenick)
Originally Posted by thenick
ok so it started working on the way to the mechanic...........we shall patiently await his conclusion
Re: (Ditdogs)
it still doesnt work... i took the harness senser off and cleaned the ****... cleaned the senser on the vss side... and still nothing... checked all ground and still nothing... thenick and i are faqing stumped... this should of been a simple thing, a plug and play thing... but it isnt.. i see alot of people haveing this same problem where they change evrything and it still is faqed up....
anyone with any info on what to do please post. thank you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by u2civic1 »</TD></TR><TR><TD CLASS="quote">i need your help guys
i replace both the VSS sensor with a new one and i also got a new cluster and my speedometer still doesn't work and i still go in to limp mode</TD></TR></TABLE>
I had a similar issue. Check fuse # 15 under your dash on the drivers side and read this post https://honda-tech.com/zerothread?id=847452 after all was said and done it turned out to be a stupid fuse...(thank god)
Solbros Owns Me
Re: Help code 17 VSS signal( i did a search) (powerBan.est1990)
I had a couple problems like this.
One was a 98 ITR, the fuse was blown. Alt/Sp fuse.
But most commonly, the connections get really corroded. Either repin them, or clean them off really good.
<FONT SIZE="6"> replace your backup fuse!!!!!!!!</FONT>
mine works now
this backup fuse is signature worthy!
mine works now
the back up fuse is the fuse you remove under the hood to reset the ECU......NOT , i repeat, NOT to be confused with the ECU fuse
