Boost gauge problem
Old Jun 21, 2008 | 05:57 PM
rustydusty1717's Avatar
Default Boost gauge problem
just curious where everyone is wiring their boost gauge's to? i wired my power and ground to my cigarette lighter but it ain't reading right. so i'm guessing i just have it wired to a shitty place. where's a better place to wire a boost gauge?
Old Jun 21, 2008 | 09:02 PM
Dartanian's Avatar
Default Re: Boost gauge problem (rustydusty1717)
If your gauge is mechanical, the wiring should only affect the lighting. What kind of gauge is it? Where is your pressure source located?
Old Jun 21, 2008 | 09:13 PM
is an electric gauge. there's 3 wires. one for power, one for ground and one for lighting. the lighting works fine it's the power and ground that arn't right i don't think. it's a sport comp 2 by the way. i've currently got it wired to the cigarette lighter but i don't think that's right. i've heard it has to be wired to something that has power even on turn-over, otherwise it reads improperly. anyone confirm that? if so where should i wire it to?
Old Jun 22, 2008 | 10:12 AM
Dartanian's Avatar
Default Re: (rustydusty1717)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rustydusty1717 &raquo;</TD></TR><TR><TD CLASS="quote">is an electric gauge. there's 3 wires. one for power, one for ground and one for lighting. the lighting works fine it's the power and ground that arn't right i don't think. it's a sport comp 2 by the way. i've currently got it wired to the cigarette lighter but i don't think that's right. i've heard it has to be wired to something that has power even on turn-over, otherwise it reads improperly. anyone confirm that? if so where should i wire it to?</TD></TR></TABLE>
One wire should be for ignition controlled 12v to power the sensor, the other wiring is for the lights. I take ignition controlled 12v directly from the under-dash ignition harness. It is a yellow wire.
When you say "reads improperly", what do you mean? If its reading anything, it is probably getting the power it needs. Check the connections to see if any are loose or poorly made.
Old Jun 22, 2008 | 11:04 AM
okay i'll try wiring it to that yellow wire.
i've heard if it's not wired to a power source that has power even when the engine is being turned over it can read improperly. think i even read that on the instructions. or is it that my gauge is possible screwed up?
Old Jun 22, 2008 | 01:34 PM
Dartanian's Avatar
What does improperly mean?
I doubt it not getting power when the key is turned over is going to affect anything.
Old Jun 22, 2008 | 02:04 PM
says it does right in the instructions. but it's reading 12 psi and i know for a fact i ain't running 12 psi. at idle it only reads 10 Hg. or -10 psi. however you read it. and i know it should be a lot lower than 10 at idle.
Old Jun 25, 2008 | 10:54 AM
welfarepc's Avatar
make sure if it has an electrical sender..... to ground the gauge to the same place as the sender.
Old Jun 25, 2008 | 02:49 PM
it's hooked up the cigarette lighter....
Old Jun 28, 2008 | 09:50 AM
if anyone could just tell me how they wired their electric boost gauge that would be exactly what i'm needing.
Jan 25, 2006 10:54 AM
ViruSi
Nov 18, 2004 07:47 PM
SuperpooV
Dec 3, 2003 05:05 PM
djnikko
Nov 28, 2003 12:35 AM
Mr. Softee
Sep 11, 2003 10:23 PM
