Boost Gauge wiring
Old Apr 22, 2003 | 10:58 AM
SuperpooV's Avatar
Default Boost Gauge wiring
I need to know where a good place to run the power wire for my friends boost gauge. He was told by a different person that it needs a 6v source and to run it to the back of the cruise control button, but I went to autometers website and it didnt say anthing about 6v. Any help would be greatly appreciated.
Old Apr 22, 2003 | 12:26 PM
dfoxengr's Avatar
Default Re: Boost Gauge wiring (SuperpooV)
any constant power source...
Old Apr 22, 2003 | 12:49 PM
Deltax75's Avatar
I dont know which boost gauge your friend has but i have a 5775 (phantom) mechanical. And the only power it needs is for the light, the directions say 12v. Hope that helps, if it doesnt we're gonna need a little more info.
-Mike
Old Apr 22, 2003 | 12:53 PM
B18EG6's Avatar
Default Re: Boost Gauge wiring (Deltax75)
easiest place to get power is the fusebox.. no tapping or splicing.
The WHITE wire is for the illumination, and the <FONT COLOR="red">RED</FONT> wire is for 12V ignition.
Hope this helps...
edit... duh forgot picture
Old Apr 22, 2003 | 03:48 PM
93dx--hatch's Avatar
Default Re: Boost Gauge wiring (B18EG6)
can i run more than one wire into that red one?
Like tach power, af gauge, etc??
Old Apr 22, 2003 | 06:07 PM
SuperpooV's Avatar
Its a cobalt series boost guage. It has the 3 wires that run to the box in the engine compartment, and then the red power, black ground and white illumination. Is that the main fuse box by the clutch pedal? thanks for your help
Old Apr 22, 2003 | 06:32 PM
B18EG6's Avatar
Default Re: (SuperpooV)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperpooV &raquo;</TD></TR><TR><TD CLASS="quote"> Is that the main fuse box by the clutch pedal? thanks for your help
yes it is
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">can i run more than one wire into that red one?
Like tach power, af gauge, etc??</TD></TR></TABLE>
yes you can
I would recommend fusing them though. Put a fise inline with the power... try a 3amp fuse for each.. or about 5 for two powers.
Dont forget to ground everytning nicely!
Old Apr 23, 2003 | 12:52 AM
SuperpooV's Avatar
thanks alot man
Old Apr 23, 2003 | 08:32 AM
B18EG6's Avatar
no problem.. if you need any help just IM me
Old Apr 23, 2003 | 08:38 AM
Canuk_SiR's Avatar
Default Re: (B18EG6)
I grabbed power off my deck. the deck has a constant 12V wire and an ignition wire. No problems with fuses, but if I ever decide to splice more into the deck power, I'll have to get some fuses and run them inline, and eliminate the fuse box fuse..
Old Apr 23, 2003 | 10:02 AM
EG6owner-T's Avatar
Default Re: (Canuk_SiR)
great info.
Old Dec 3, 2003 | 07:13 AM
RedTegLS's Avatar
Default Re: (EG6owner)
In the autometer instructions it says to look for a source that is not constant to preserve bulb life. Its a good point but is there anything in the fuse box that is only power when your lights are on?
Old Dec 3, 2003 | 07:56 AM
B18EG6's Avatar
Default Re: (RedTegLS)
yeh... the white wire in that pic
Old Dec 3, 2003 | 09:56 AM
Foozball26's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedTegLS &raquo;</TD></TR><TR><TD CLASS="quote">In the autometer instructions it says to look for a source that is not constant to preserve bulb life. Its a good point but is there anything in the fuse box that is only power when your lights are on?</TD></TR></TABLE>
yes, if you don't have the fuse panel cover that shows you where your headlight fuse is, then get a multimeter and find it, just tap into that with the white wire and when your headlighs turn on so will the guage illumination.
Old Dec 3, 2003 | 11:30 AM
B18EG6's Avatar
Default Re: (Foozball26)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Foozball26 &raquo;</TD></TR><TR><TD CLASS="quote">
yes, if you don't have the fuse panel cover that shows you where your headlight fuse is, then get a multimeter and find it, just tap into that with the white wire and when your headlighs turn on so will the guage illumination.</TD></TR></TABLE>
yeh.... the white wire is what has power when the lights go on... you dont need to tap into a existing fuse, there is a port on the fusebox that is empty and you can just get some female spade solderless connectors, and plug er in
Old Dec 3, 2003 | 05:05 PM
Foozball26's Avatar
yea, i mean tap into with a connector, dunno anyone that would tear into a panel for a wire
i got an adapter from autozone that holds 2 fuses and plugs into the panel and the other fuse has a wire comming off of it for a guage or whatever.
da_ska
May 31, 2009 07:24 AM
rustydusty1717
Jun 28, 2008 09:50 AM
IIVIIoOkY
Apr 30, 2007 11:28 PM
91tegrals
Mar 10, 2004 06:49 AM
