which block?
i was thinking of doing an ls/vtec motor. i dont know if i should buy a dart block or jsut buy a stock block and sleeve it. is there really that much of a difference? also ould it be better just to build up a gsr instead of an ls/vtec?
If you have the financial capabilities to afford the dart block, then go for it. You should also consider your goals. Are you building it for an all motor setup? A turbo setup? nitrious? We need details to better answer your question.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxstreetracer90 »</TD></TR><TR><TD CLASS="quote">the dart block is an ls block right? so wouldnt i have to get the oil lines and stuff or am i wrong?</TD></TR></TABLE>
Ok dart carries either of those blocks! Also if u do an LS/VTEC u do need those oil lines and tha dowel pins, but if u do GSR block u dont need em
NICOSLOW
Dec 23, 2009 05:04 AM
ABCVTEC
14
Nov 15, 2006 08:59 AM
jamal-188
Apr 29, 2002 05:40 AM
