which block?
Old Sep 19, 2004 | 12:39 PM
EFin' Kyle's Avatar
Default which block?
i was thinking of doing an ls/vtec motor. i dont know if i should buy a dart block or jsut buy a stock block and sleeve it. is there really that much of a difference? also ould it be better just to build up a gsr instead of an ls/vtec?
Old Sep 19, 2004 | 01:51 PM
Kendall's Avatar
If you have the financial capabilities to afford the dart block, then go for it. You should also consider your goals. Are you building it for an all motor setup? A turbo setup? nitrious? We need details to better answer your question.
Old Sep 19, 2004 | 02:56 PM
EFin' Kyle's Avatar
Default Re: (Kendall)
sry i am planning on building an all motor setup. i already have a gsr head i just didnt know where i should go with it. ls/vtec or gsr? and what block
Old Sep 19, 2004 | 05:43 PM
SLOW EF8's Avatar
Default Re: (crxstreetracer90)
LS or GSR block is both fine if ur going to sleeve it, but if u have tha money just buy a DART block
Old Sep 19, 2004 | 05:56 PM
EFin' Kyle's Avatar
Default Re: (HybridEF8)
the dart block is an ls block right? so wouldnt i have to get the oil lines and stuff or am i wrong?
Old Sep 19, 2004 | 06:06 PM
SLOW EF8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxstreetracer90 &raquo;</TD></TR><TR><TD CLASS="quote">the dart block is an ls block right? so wouldnt i have to get the oil lines and stuff or am i wrong?</TD></TR></TABLE>
Ok dart carries either of those blocks! Also if u do an LS/VTEC u do need those oil lines and tha dowel pins, but if u do GSR block u dont need em
Old Sep 19, 2004 | 06:57 PM
EFin' Kyle's Avatar
but isnt a gsr block more than a ls block? also does n e one know how much hp a ls/vtec would make with all stock parts?
Old Sep 19, 2004 | 07:15 PM
SLOW EF8's Avatar
I dunno bout tha price! but for HP it varies, its not like a constant HP once u put all stock parts!
Old Sep 20, 2004 | 06:30 AM
EFin' Kyle's Avatar
ok say it was a b18a1 block with a b18c1 head. would that be more specific?
NICOSLOW
Dec 23, 2009 05:04 AM
ABCVTEC
14
Nov 15, 2006 08:59 AM
aberkrombie
Sep 16, 2004 12:29 PM
SupaFly_Honda
Feb 17, 2004 06:40 AM
jamal-188
Apr 29, 2002 05:40 AM
