B18b into an EM1
Old Sep 15, 2004 | 12:49 AM
JDMflavor_EJ's Avatar
Default B18b into an EM1
Searched and couldn't find too much due to the specifics that I am requesting.
My cousin has a 00 Si that was hit from the front a couple weeks ago, the motor was damaged.
He picked up a 95 LS for next to nothing.
He had a chipped p28 with an OBDI harness like everyone else...but now...
What ECU do we use? (thinking of going Hondata), can we retain the stock engine harness if we use a OBDII LS ecu - will it plug and play right up to the engine harness/OBD1 harness?
And after that one, what Hondata would be ideal, possibly boost in the near future.
Thanks.
Old Sep 15, 2004 | 12:56 AM
chads's Avatar
Default Re: B18b into an EM1 (JDMflavor_EJ)
i feel bad for your em1
Old Sep 15, 2004 | 01:00 AM
JDMlyfestyle's Avatar
here you go
Old Sep 15, 2004 | 05:46 AM
Default Re: (JDMlyfestyle)
Sorry but it didn't help at all.
The EK years stopped short of the B18b years.
ECU: By far the easiest ecu to use in most situations is the p30 from the 96-97 Del sol Vtec. only a few modesl of the 99-00 civics need the 99-00 Si ECU. For more info see Elctrical Differences below. Chipped P28 can be used if a OBDII to OBDI harness is used. May not be smog legal in CA.
So...I use a p30?
Old Sep 15, 2004 | 11:35 AM
Default Re: (JDMflavor_EJ)
TTT
Old Sep 15, 2004 | 11:43 AM
Yeung's Avatar
front end collision with motor damage.. and the car isn't totalled?
Old Sep 15, 2004 | 12:06 PM
ABK's Avatar
ABK
Default Re: (Yeung)
just run obdII LS ecu. Or get a chip for that p28 with LS program. I got a obdI LS ecu for sale if you wonna buy it and use it with a harness. It's auto but it seems to be running fine in a 5spd d16z6. Only at warmup idle is kind of wrong. I could prolly chip it though.
xXxHOLYMANxXx
Jul 19, 2012 03:39 PM
pine_apple45
11
Mar 20, 2007 08:12 PM
BlKdOutEk
Sep 16, 2005 11:53 PM
JDMflavor_EJ
Sep 15, 2004 06:35 AM
kholmes
Aug 28, 2003 06:40 AM
