Compression test 240 all across ...but
i am still getting oil from my wastegate dump tube
whats my problem
my turbo has no shaft play runs good , but oil coming from my wg dump tube
whats my problem
the seals in your turbo. You need to replace them and put a pressure reducer in your feed line.
*I was thinking downpipe...would that be the same diagnosis?*
why put a pressure reducer in my feed line , am i getting too much oil in my turbo? the old feed line i had was bigger than the new one i just put in
external wastegate? What kind of manifold? I have trouble visioning how oil is traveling up against the exhaust flow and out your wastegate. (assuming it's mounted on the manifold before the turbo...
i have a t3/t4 turbo inlinepro manifold tial 35wg
with stans feed and return lines
i didnt have this problem before until now
that i took of teh turbo and put in a new feed line
if there is oil in your dumptube your motor should be smoking. the same exhaust gas that passes thru the dumptube passes thru your exhaust also. it is extremely hard to diagnose the source tho with the provided info
here is what my new feed line looks like
i couldnt put a 90degree apatper there cuz i couldnt move the turbo so i can put it in there
is not youre feed or any lines for that matter if its coming out of your wastegate. its not the turbo seals either, like stated before it must be comming out of your engine, maybe valve seals or something.
Landon
Landon
it could be the oil rings as well couldn't it? Cyphear's car is blowing smoke out the exhaust and thats the only thing we can figure out. (Note: Car ran fine before, then blew motor. Changed bottom ends and now smokes.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">most turbos only wanna see between 45-60 psi. Under boost your turbo probably sees 75+ at WOT</TD></TR></TABLE>
Kidding? That much pressure inside the turbo and it will be leaking oil like a seive. The point is to make the feed constrictive enough and the drain line large enough so that there is almost no oil pressure inside the turbo.
take off your exhaust mani and let the engine run see if oil sputters out the exhaust. But plug up your feed line. If nothing then work your way towards the other conponents.
doing that will that harm anything?>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by svmnredracr »</TD></TR><TR><TD CLASS="quote">take off your exhaust mani and let the engine run see if oil sputters out the exhaust. But plug up your feed line. If nothing then work your way towards the other conponents.</TD></TR></TABLE>
You won't hurt anything but your ears.
The myth that running open header or without an exhaust can fry exhaust valves was only true in older engines with sodium-filled valves.
