turbo install problem HELP OIL LEAK
Old Jun 20, 2004 | 08:04 PM
illicon2003
Guest
Posts: n/a
Default turbo install problem HELP OIL LEAK
the oil feed tee fitting just loves leaking. first time it was leaking out of the block..so I torque it down hard(got it to turn an entire turn into the block with plyers).....went to start it up and it'still leaking but not sure where from this time....I think it could be the feed adapter to the tee fitting now for the oil feed....I don't know..... help me please....
Old Jun 20, 2004 | 08:24 PM
Chillinit's Avatar
Default Re: turbo install problem HELP OIL LEAK (illicon2003)
those are npt threads....they required some teflon tape or paste....are you using any?
Old Jun 20, 2004 | 08:31 PM
illicon2003
Guest
Posts: n/a
nope....ill try that tommorow..should I use it only on the NPT threads? ...thanks
Old Jun 21, 2004 | 04:03 AM
Chillinit's Avatar
Default Re: (illicon2003)
yes..only on npt and bspt...which are both tapered..do not use any on AN threads
Old Jun 21, 2004 | 06:06 AM
Flamenco-T's Avatar
Do you have any BSPT adapters on it ? You may want to be careful about tigtening to the block.
Chilinit is right, no teflon tape on the AN threads.
stan
Old Jun 21, 2004 | 01:12 PM
d16y8turbo's Avatar
are you using the banjo fitting that comes with the kit for the oil feed on the turbo? if so than don't overtighten it. i had to improvise cause i broke mine. those fittings aren't strong, or cheap.
also, why don't you just call my cell instead of im if you wanna get in touch?
Old Jun 21, 2004 | 08:06 PM
illicon2003
Guest
Posts: n/a
teflon tape helped alot....no leaks for 20 minutse...thanks guys
ÁrniMkv
Feb 10, 2012 07:02 AM
Civicman86
Oct 14, 2006 12:18 PM
ozzyman
Jul 6, 2005 10:47 PM
jdm2ner
May 15, 2005 12:52 AM
nonvtec
Sep 8, 2003 12:03 PM
