need help locating a part
Old Sep 8, 2003 | 10:38 AM
nonvtec's Avatar
Default need help locating a part
Does anyone know wher eu can buy a turbo oil return kit that screws on in between your oil filter and block and has the lines coming out the sides of the spacer?
Old Sep 8, 2003 | 11:53 AM
IMALLSLO's Avatar
Default Re: need help locating a part (nonvtec)
An oil return is basically gravity fed(the reason its placed below the turbo). If you place the return fitting above the drain you may have the problem of oil backing up into the turbo and blowing the seals costing you $$$$$$$$$$$. I dont recommend it although it would be nice
Old Sep 8, 2003 | 12:03 PM
raene's Avatar
That's an oil feed kit. I believe as stated above you still need the drain pan fitting
Sorry, I should've mentioned, GE makes one.
wunest
Apr 8, 2010 10:12 AM
speedfoxracing
Jan 18, 2010 03:14 PM
Civicman86
Oct 14, 2006 12:18 PM
15psi of fun
Feb 4, 2003 10:17 PM
2000GSRT
Nov 10, 2002 06:38 PM
