turbo problems help
Old May 11, 2005 | 04:46 PM
jdm2ner's Avatar
Default turbo problems help
I have a 97 gsr and I turbo charged my car but i have a problem with my oil feed line, its not feeding any oil to my turbo. please help me!
Old May 11, 2005 | 05:35 PM
sykotic's Avatar
Default Re: turbo problems help (jdm2ner)
where do you have it hooked up to on your engine? You should have a T brass fitting on the back of your block with the oil line hooked on top and your oil pressure switch on the other fitting, if you have that correct then have you tried starting the engine for a few seconds with the line disconnected from the turbo to see if oil comes out?
Old May 11, 2005 | 05:48 PM
jdm2ner's Avatar
I do have a t-fitting. I have oil line-T-to block and on the bottom I have the oil pressure switch. I did diconect the oil line from the turbo to see if oil did come out but no oil
Old May 11, 2005 | 08:02 PM
Johnny_Rocket's Avatar
sounds like the hose is kinked... Might be a long shot but did you actually start the car up with the oil line off? It won't shoot anything out unless it's running... Just making sure
Old May 11, 2005 | 08:12 PM
Kendall's Avatar
It's possible that the line is clogged with something. Did you use a brand new line? Also may I recommend removing the turbo from the motor until you get it figured out, nothing quite like oil starvation to ruin a perfectly good turbo.
Old May 12, 2005 | 08:13 AM
jdm2ner's Avatar
i disconented the line and started the car. no oil came out. i did use a new braided line. no kink in the line.
Old May 14, 2005 | 11:12 PM
Default Re: (jdm2ner)
What do you have it hooked up to?
Old May 15, 2005 | 12:52 AM
94DelSolT's Avatar
Default Re: (JohnnyH)
Do you have a Oil Pressure Gauge? If so, are you reading pressure? If no then your oil pump is bad. if yes, Then You could have something as dumn as me, My hose got clogged with some of that tape that i used around the brass fittings.
ÁrniMkv
Feb 10, 2012 07:02 AM
94preluder3084
Jun 8, 2007 09:46 AM
ninja8oi
Jun 12, 2005 06:20 PM
blufke
Nov 4, 2002 10:25 AM
