knock sensor...plug deal comes off....
Old Apr 24, 2004 | 10:53 AM
hondaeg8's Avatar
Default knock sensor...plug deal comes off....
i just got a jdm gsr motor and the knock sensor comes off. not the part on the block, but the black part that you plug the harness into. i can put it back on, but it fits very lose. this mean the sensor is broken now? would i be able to use it like that?
Old Apr 24, 2004 | 11:11 AM
91DA9's Avatar
Default Re: knock sensor...plug deal comes off.... (hondaeg8)
You might be able to solder it back together but your best bet is to get another.
Old Apr 24, 2004 | 04:47 PM
hondaeg8's Avatar
Default Re: knock sensor...plug deal comes off.... (91DA9)
i just pushed it back on for now. i just want to get the motor in the car to see how its going to sound. hopefully steve from hmotorsonline will send me another one along with the throttle body sensor that was missing.
Old Apr 24, 2004 | 10:24 PM
91DA9's Avatar
I'd make sure you use premium, just in case.
Old Apr 25, 2004 | 02:02 AM
Trac226's Avatar
Same thing I just went through this weak. I guarantee you that the weak *** knock sensor is jacked and its going to dump hella fuel and retard your timing when you start up the car. You won't get a CEL right away but you will eventually. Get it fixed now and save some time. 27mm
CaliforniaDad
Mar 14, 2016 04:45 PM
Boost_em1_
May 29, 2014 04:21 AM
maomaniarocks
May 4, 2007 09:33 PM
untitledsn41
Jul 30, 2004 04:48 AM
beanbag
Jul 3, 2004 08:57 PM
