Such thing as a performance knock sensor??
Old Mar 4, 2016 | 06:01 AM
CaliforniaDad's Avatar
No-Traction = Fun
Default Such thing as a performance knock sensor??
I'm going replace all my sensors on this new build of mine and was wondering if there is a performance knock sensor avalible?
Never understand why they range from 10.00-150.00
Old Mar 4, 2016 | 06:52 AM
turbohatch96y7's Avatar
Get a bosch sensor and wire that up to your aem. Youll need to "tune" it for your motor. Easiest way to do that is to induce knock at low loads then get the freq you hear the knock and dial it in from there.
Since youll have a motor with a large ptw gap youll have some piston slap. There isnt going to be a one size fits all setting for a built motor and a knock sensor.
You have individual coils so you can pull timing or fuel out of 1 cylinder at a low load to where you get just a slight sound of knock.
At that point you datalog the knock sensor and set a thresh hold for knock.
Anything above that thresh hold will be considered knock. The aem will pull timing and add fuel depending on how severe the knock is
Are you using a gsr block? That would be easy to add the sensor in.
Old Mar 4, 2016 | 06:54 AM
Give this a read
It should apply to the infinity
http://www.efi101.com/forum/viewtopic.php?t=7972
Old Mar 4, 2016 | 06:59 AM
Black R's Avatar
25 Year Member
Default Re: Such thing as a performance knock sensor??
I bought this kit:
www.viatrack.ca
I haven't installed it yet though.
Old Mar 4, 2016 | 07:44 AM
ls joker's Avatar
Loved
how the hell did you become a curtis
Old Mar 4, 2016 | 07:47 AM
No idea
Old Mar 4, 2016 | 07:50 AM
ls joker's Avatar
Loved
wow
Old Mar 4, 2016 | 07:52 AM
Whats a Curtis? I think youre using it in a different meaning
Old Mar 4, 2016 | 07:58 AM
ls joker's Avatar
Loved
nice, you changing my post.
sorry for the detour
Old Mar 4, 2016 | 08:11 AM
Aradin's Avatar
Premium Member
I want summadat
Old Mar 5, 2016 | 11:15 AM
Flr Power's Avatar
Use the stock. It works well and only has to be calibrated with your EMS.
Old Mar 7, 2016 | 03:39 PM
No-Traction = Fun
Talked to Beau @ AEM he recommended me to use the Donuts style Bosch knock sensor. So that what im going to do. The OEM sensor it noisy.
Old Mar 7, 2016 | 04:08 PM
Ping knows a lot more about our motors
Did you look at the thread i linked?
Old Mar 7, 2016 | 05:16 PM
Flr Power's Avatar
The OEM sensor is not noisy. Here's proof. Look at the bottom orange graph pull from 2000-6200 rpm. Highest reading is about 1.8 volts...
Old Mar 7, 2016 | 06:48 PM
Turbo-LS's Avatar
Its not terribly noisy but could be cleaner, though I bet that would clean up with filtering in the aem software anyway
Old Mar 8, 2016 | 07:14 AM
Flr Power's Avatar
Yes it's fully adjustable so when you throw in loose ptw pistons and aggressive cams/springs the now different engine noise signature can be filtered out somewhat pretty good even with the stock sensor.
Old Mar 8, 2016 | 12:25 PM
No-Traction = Fun
hmmm...Good to know guys
Old Mar 8, 2016 | 12:37 PM
bigG's Avatar
is hat aem v1 or just v2?
Old Mar 8, 2016 | 12:41 PM
Flr Power's Avatar
Only V2 has knock fully adjustable. Although this is more depending on firmware
Old Mar 14, 2016 | 04:45 PM
Black R's Avatar
25 Year Member
Here's a good one:
http://plextuning.createsend1.com/t/...4648E03FD1D4F9
Knock Monitor V2 from Plex Tuning
http://www.plex-tuning.com/products/...nitor-v2-0-new
$899-$999 usd!
gabrielsousa
Nov 4, 2015 04:12 PM
98vtec
Aug 18, 2006 07:12 PM
rice is nice
Apr 14, 2005 08:46 PM
DR. ON POINT
Dec 12, 2001 12:26 PM
