No vacum
Old Apr 20, 2004 | 02:13 PM
B20fun's Avatar
Default No vacum
I have a Jg intake manifold on a ls head and crower cams that have 243 / 246 duration, under 1000rpm there is no vacum and it is really hard to get the car to idle w/out over fueling it. Would this be a leak or a combination of the cams and cam timing.
Thank you
Old Apr 20, 2004 | 02:36 PM
LSVTEC 91 Civic's Avatar
Banned
Default Re: No vacum (B20fun)
What are the cams set to?
Are there any vacuum leaks anywhere?
Old Apr 20, 2004 | 04:20 PM
B20fun's Avatar
Default Re: No vacum (LSVTEC 91 Civic)
The cams are set to 0 and I tried everything I could think of to find vacum leaks and didn't find a thing
Old Apr 20, 2004 | 09:45 PM
B20fun's Avatar
I just looked at it again and it does make it up to about 5in at 1000rpm w/the throttle closed.
Old Apr 21, 2004 | 02:14 PM
B20fun's Avatar
Is there a way I can change the cam timing to get more vacum
Old Apr 21, 2004 | 07:01 PM
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B20fun &raquo;</TD></TR><TR><TD CLASS="quote">Is there a way I can change the cam timing to get more vacum</TD></TR></TABLE>
Old Apr 21, 2004 | 10:27 PM
B20fun's Avatar
Well I guess I will try to get it running good without vacum
Old Apr 21, 2004 | 10:50 PM
mmuller's Avatar
Mad Scientist
you could try reducing overlap by advancing the exhaust and retard the intake
Old Apr 21, 2004 | 11:05 PM
BuddhaSiR's Avatar
Default Re: No vacum (mmuller)
no vacuum, make sure you have no leaks anywhere. doesn't sound good if you don't have any leaks.
Old Apr 21, 2004 | 11:27 PM
B20fun's Avatar
Default Re: No vacum (BuddhaSiR)
I made sure again today there was no leeks I will try the cam timing tomorow. Is there a chance it could be the valves, they are jg stainless.
Old Apr 21, 2004 | 11:45 PM
BuddhaSiR's Avatar
did you do a valve job when you installed the valves? the valves could not be seating properly.
Old Apr 21, 2004 | 11:53 PM
B20fun's Avatar
I did do a valve job when I got the valvles but something could have gone wrong. Would a comp check show any problems.
Old Apr 23, 2004 | 03:13 PM
BuddhaSiR's Avatar
do a leak down test. that should definitely tell you whats up. you can also lap the valves to see what kind of a seat you're getting.
Old Apr 25, 2004 | 02:27 AM
B20fun's Avatar
Thank you
dbiker207
Jun 9, 2007 09:02 AM
miggittymacdaddy
Jun 9, 2004 05:10 PM
ClubSiRacer
Apr 6, 2003 09:25 AM
Irate
Mar 11, 2003 06:52 PM
