turbo ls hatchback having problems??
Old Mar 21, 2004 | 07:41 AM
Cornwhiskey's Avatar
Default turbo ls hatchback having problems??
we turbo my friends 89 ls hatchback and it is throwing map sensor code check engine lite comes on car will start jerking we put check valves in it but the car want even run if u do that can anyone tell us whats going on with this thing.
Old Mar 21, 2004 | 08:08 AM
Kendall's Avatar
I'm sorry, but could you be more vague? We need to know information about the setup, most notably what kind of engine management. You do know that the stock MAP sensors don't like boost don't you? Just adding check valves won't necessarily do anything for you.
Old Mar 21, 2004 | 09:08 AM
Default Re: (Kendall)
it is a t3t4 setup tailwastegate front mount rfl bov boosting 5lbs stock injectors stock fuel pump aem fuel rail and press reg. and it is a stock map
Old Mar 22, 2004 | 11:03 AM
Default Re: (onefastcrx88)
help???
Wink1100
Sep 3, 2007 06:39 AM
Cornwhiskey
Mar 23, 2004 06:57 AM
turbo89civicb18hatch
Mar 11, 2004 10:59 AM
twkdCD595
Jun 5, 2003 07:50 AM
HybridCoupe
Apr 25, 2003 10:55 PM
