map sensor problem on 90 teg...
Old Jun 3, 2003 | 04:07 PM
twkdCD595's Avatar
Default map sensor problem on 90 teg...
friend of mines car is giving him all **** at anything over 6 psi and he hits a check engine.
he already has 4 check valves tee'd in but it still is not enough.
what are you ls 1.8 turbo guys going for the funky map ****... he cannot get much to work and any suggestions will help.
Thanks.
Old Jun 3, 2003 | 06:31 PM
twkdCD595's Avatar
Default Re: map sensor problem on 90 teg... (twkdCD595)
bump
Old Jun 3, 2003 | 07:42 PM
Tinker219's Avatar
smc here, works great, and cheaper than FMU/check valve setup. Well, its my bros car...
Old Jun 4, 2003 | 06:15 AM
twkdCD595's Avatar
Default Re: map sensor problem on 90 teg... (Tinker219)
how much and were do you get them.
my buddy JL is wanting to up the boost but this is the only hold back... he has a built motor and poopy fuel management.
Old Jun 5, 2003 | 06:45 AM
twkdCD595's Avatar
any other suggestions?
Old Jun 5, 2003 | 07:50 AM
Kwuaymaikrup's Avatar
Why not bust out the credit card and buy some real fuel management and a 3 bar map??? If it is giving you problems now imagine what it will do with more boost. No sense loosing a built motor over something like this. The only real solution IMHO. Good luck
-Ryan
shaggyeg6si
May 15, 2008 07:48 AM
rdssk8rcs1
Oct 10, 2006 06:43 AM
silverbulletgsr
May 20, 2004 08:24 AM
OVERBOOST TEG
Oct 30, 2003 10:49 AM
incognitoracerr
Jul 14, 2003 06:17 AM
