check engine light comes on when i boost....
Old Jun 30, 2002 | 04:18 PM
HybridCoupe's Avatar
Default check engine light comes on when i boost....
my car is running alright its a 95ls turbo but when im boosting my check engine light comes on and i dont know why...when i try to check the engine code it wont flash...also my car is reading like 50 when i boost on my safc under the throtle 2 which is very lean....
Old Jun 30, 2002 | 05:09 PM
CovertFI's Avatar
Default Re: check engine light comes on when i boost.... (HybridCoupe)
what is your full set up? do you have a check valve on your map sensor?
Old Jun 30, 2002 | 05:21 PM
SlowB16's Avatar
sounds like a map
Old Jun 30, 2002 | 05:22 PM
TurBoXBirD16's Avatar
Default Re: check engine light comes on when i boost.... (SlowB16)
sounds like a map
Old Jun 30, 2002 | 05:40 PM
Default Re: check engine light comes on when i boost.... (xbird)
i have a missing link on my map sensor....and my car is bukking real bad...my full setup is 93 coupe with 95 ls motor with drag 3 trubo kit boosting 4psi with a vortech fme 12:1 with walbro 255 intank fuel pump and stock injectors
Old Jun 30, 2002 | 05:51 PM
ion_four's Avatar
I installed a JG TB on my car a while back and the CEL came on, but it wouldn't blink when I jumped it...weird. I knew it was either the MAP or TPS...it turned out to be the TPS and I had to turn it just a tad and it went away. really queer.
Old Jun 30, 2002 | 07:06 PM
AlphaKennyWun's Avatar
sounds like a map
Map
Old Apr 25, 2003 | 10:20 PM
genyosai's Avatar
My check engine light comes on sometimes at about 8,000rpm and goes right back out when the rpm drops. I check for codes and there are none. Any ideas? I'm running a built GSR motor and 12psi using Hondata and GM 3bar MAP:
thanks,
Old Apr 25, 2003 | 10:26 PM
done's Avatar
Default Re: check engine light comes on when i boost.... (genyosai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by genyosai &raquo;</TD></TR><TR><TD CLASS="quote">My check engine light comes on sometimes at about 8,000rpm and goes right back out when the rpm drops. I check for codes and there are none. Any ideas? I'm running a built GSR motor and 12psi using Hondata and GM 3bar MAP:
thanks,
does knock sensor throw a code?
Old Apr 25, 2003 | 10:47 PM
genyosai's Avatar
Default Re: check engine light comes on when i boost.... (Jordo)
Hmmm... not sure. I don't think so. When I had my 96 GSR, I had some bad gas once that caused the car to ping baddly... the knock sensor never threw a code.
You think maybe Im getting some "piston slap" from my forged pistons and rods... falsely being detected as detonation? Since I have Hondata, I wonder if it would be wise to turn the knock sensor off.
Old Apr 25, 2003 | 10:55 PM
T-sohctec's Avatar
I know this kinda off topic but damn you can drive that car!
260WHP & 11.9's nice! in a coupe.
eaz_e
May 15, 2009 05:03 AM
incognitoracerr
Jul 14, 2003 06:17 AM
ion_four
Aug 11, 2002 07:06 PM
HybridCoupe
Jul 1, 2002 11:11 AM
